I always thought jdm dc5r came with only front brembo's??? to answer your question no it's not a direct fit without the aid of upgrading to s2k rotors which will effect your offset.
Some more info here about the brembo upgrade: http://www.ozhonda.com/forum/showthr...possibly-EURO&
meh.. Im still lost, so you would need S200 rotors to fit JDM DC5 brembo brakes to fir on an ep3 etc?
If so why not use the standard DC5 rotors as it will not have the clearance issues? And to run s2k rotors and them have to use a low offset to clear the rim seems too much when wanting to keep stockish off set, but then again I think that any wheel with enough clearance would be good for the job?
I thought it was pretty clear in the link I provided the other day?
If you thought JDM Brembo conversion required the whole DC5R driveline, you are sadly mistaken!
It didn't make sense to me why people had to change the entire knuckle, LCA, driveshafts etc. to do this. Then I heard that the problem was simply that the Brembo calipers centre line was some 7.5mm further out than ADM DC5/EP3/FN2/AP1 calipers. If that was all, how hard can it be? I sourced some DC5R Brembos for a decent price, and bolted it up. The standard brake lines and caliper bolts fitted with no hassle at all! and surely enough the ADM DC5/EP3/FN2 rotors were sitting too far inside by 7.5mm. At first I fabricated some 7.5mm spacers and that fitted fine before I realised that S2000 rotors have exactly 7.5mm less offset than ADM DC5/EP3/FN2 rotors.
So out I go to source some cheap S2000 rotors. When they came I trial fitted them on some spare DC5 knuckles and woohoo perfect fit, then I bolted it them up to my FN2, another perfect fit! The only downside to this install is you need quite an agressive offset wheel to clear the Brembo Caliper, I'm using 18*7.5 +30 and 17*8 +38 wheels to clear the caliper.
The main difference between the EP3 rotor and S2K rotor is the hat size. Which again is shown in the link. One is taller EP3, the other is shorter S2K. As the EP3 rotor is taller, it sits back too far to sit in line with the Brembo caliper. By using the S2K rotor, being 7.5mm shorter. It moves it out/forward to sit inline with the Brembo caliper.
The Brembo calipers are a bit wider/bigger, hence you need to either run spacers on the EP3 stockies, or run lower offset wheels to clear the calipers.
