No it makes no noises at all actually I've had it full lock both ways and there is no sound
check if your lug nuts are on tight?
Hey guys
I was planning to buy a new honda ep3 typeR but i am not sure what to look for?
Not sure how much power at the wheels standard but was thinking to put cams later on what do you guys think?
Hey mate,
Check out johno's thread. It's a great guide.
http://www.ozhonda.com/forum/showthr...ide-EP3-buyers!
Why jump straight to cams? Are you looking at similar cars and thinking the power figures could be a bit higher?
If it helps my mate has a 2006 WRX (think they are 180kw??) which is pretty well on par with my EP3 (excluding the jump). Mine has only an exhaust and intake. With headers and a tune it might be in front even. Didn't test it on the road btw.
What I'm trying to say is don't get too caught up with figures on paper. EP is a machine :)
I know what your trying to say its weight over power the ep is quicker. but in terms of k24 would it be similar to a k20 if i put cams and to do the top-end? im in the market for one in mid june so im just doing a bit of research i didnt want to go turbo becuase i can easily buy a evo but i want Honda N/A.
or is there a differents between ep3 and the new typeR? im not sure the difference...
Took my bumper off the other day to restore my grill from its dull and charcoal look, and after fitting my bumper back on, the drivers side won't align well where it meets the grill meets the headlight. The passenger side is fine.
Attachment 21772
Not sure if it was there before i took my bumper off cause i've only noticed it after putting it back on, but it looks as if it is bent. Previously I had a 4wd reverse into that area right infront of me (guy was a total ass, claims his reverse sensor and camera didn't see it and called me a liar, even when alarm went off). Maybe that could have made it like that. I've tried taking it off several times to adjust the brackets and headlight with no luck :(
There are quite a few differences as far as I understand it. This should sum most of them up:
http://www.youtube.com/watch?v=PaYW1mUE8RI
