Is that what you have??? or someone you know???
seems interesting
i work at an car audio shop and my preference in terms of quality and reliability is the cx 609a
but i just talked to my clarion rep and apparently the new one is coming out soon
nx709a with screen and bluetooth and usb the whole 9 for roughly the same price
Buy kenwood DDX series head unit roughly around $600+. save up a bit then buy garmin no map gps hide away around $300 (everyone knows garmin is the best GPS) then find your self a 'map' :D
i cleaned my car today :) its been so LONG since shes semi shined!
http://i301.photobucket.com/albums/n...g?t=1280149151
still not low enough... LOL
love the dish
really struggling to sell them bbs dez =S
I can't remember if I read this somewhere here or not... but is it true that there is no way to maintain the steering wheel button functionality once we change our headunit?
Isn't there some sort of adapter we could use? Mainly just after ipod connectivity + control with the steering wheel... =)
depends on what brand is your HU, im using swi jack wired to steering wheel control button with kenwood HU and everything works perfectly, track up down, volume up down, and source button. most of aftermarket hu has ipod adapter.
There is always a way, just sometimes more complez and expensive
Okay a pic of my ride:
http://www.ozhonda.com/gallery/data/509/Civic_Front.jpg
Whats the best place to source the double din kit? JDM has it for $250, i saw another place that wanted $260. Anyone found a good place for cheaper? obviously need the dark grey/charcoal looking one.
I've got a bunch of spare carbon fibre wrap pieces at home...what should I wrap? :P
no, you can always get the steering wheel controls working, all you need is a pac swi jack. around $150-250 depending where you buy. mine looks like this, not sure if there is an upgraded version
https://www.caraudiowarehouse.com.au...s/swi-can2.jpg
^ i have the blue one which is smaller than that, might be the upgraded version?
Oh cool, thanks for the info guys.
Bit expensive though for such a little thing :S
nice thread but more photos will be ok
For all steering wheel control, all to do is just buy a adpter from JB Hifi, Car sound dealer, .... I had mine done with Alpine headunit on FD1, work well
Can someone tell me where I can find a switched 12V source of power in the FDs, preferably switched on when it's within the 'on' region instead of 'acc'.
I know that there are a few fuse locations that have this, but the wire that I'm connecting already has a fuse connected inline with it...so I just thought there would be an alternative.
Thanks!
newest mod : egg on a bonnet. took some of my clear coat off too =.= fking rats.
http://img842.imageshack.us/img842/7339/28072010538.jpg
Like old said: It is good for skin. lol so it is good for paint :D
fkn scum dez.. hope it all works out ok w/ ur paint
[QUOTE=ekdez;2809528]newest mod : egg on a bonnet. took some of my clear coat off too =.= fking rats.
Sux Bro. Hope all's well.
I didn't know an egg could be so evil
If I were to purchase a turbo kit for the Civic Si, will it work on our engines without throwing codes? I'd be looking at using a full aftermarket ecu such as motec or hondata
starter motor connection in the fuse compartment inside the car
hows the scrubbing with that wheel set up dez? had anyone sit in the back yet?
OH IT WAS AN EXPERIANCE>!!!
had a girl in the front and a girl in the back.. and it was terrible.. FML! never again will i have a person in the back seats..
i felt like kicking them out and putting a NO FAT CHICK's CAR WILL SCRAPE sticker on it.. even tho the girls weight less then 60 each..
drove with a mate in the front.. and it was ok.. still scrubs a bit.. but bearable..
TBH.. x9.5 is too wide on the rear. if u can get a x9" with 1 or 2 mm less poke then mine you'll be laughing. x8.5 +25 at the front is BOSS
HAVING SAID THAT.. ive dont a shit load of work to my car to make those x9.5's with 225/35 fit..
but.. x9.5 +30 and at my height.. no inner clearance issues.. just the outter.
Something's wrong with my car :(
I pulled out the #3 fuse labelled "IG1 ACG" so I could use my multimeter and see if it was the right fuse that I wanted to tap into. After putting the original fuse back in, the fuel pump light is constantly lit up!
The car starts and all, unsure whether it actually goes or not as I'm too scared to try.
Have I totally screwed it up?
any of you guys removed or replaced the muffler resonator (hotdog)? if so how'd it sound? I'm thinking of removing mine but don't want it to be overly loud
I'll try that now. Do you mean leave it 'out' instead of in, or are you referring to something else?
Will I have to do this every time I remove the fuse #3?
Wouldn't this also reset my radio as well? I might need to find the code for that... where is it normally? =\
i dont think u need code
just take the +ve plug off and plug it back in
hmm i believe you will need to put in the code for the radio after reset. hmm not sure
No one here removed or replaced their exhaust resonator?
Btw is there one or two or them?
ive removed mine
and its only one
with J's racing exhaust its nice but quite loud!
i removed it, so straight pipe
at around 3000 - 4000 rev, OMG sounds so LOUD!
its very hard to describe, its very unique
I just had a look under the car and near the rear driver side wheel there is a muffler that looks like a hotdog, and about halfway under the car theres a smaller barrel looking resonator...
man talk about sound/emmission control.
which one did you remove? should I remove both?
I noticed on the J's fd2r catback exhaust they've made it a straight pipe where the hotdog is meant to be but kept the smaller resonator just after the cat...
http://i57.photobucket.com/albums/g2...ckfd260rsp.jpg
So I guess this is what I should do!
hey guys.. anyone know where can i buy just the front mugen lips for civic FD 07? thanks..
OTR in clayton, give then a call and see if they have any in stock
called.. but they seems dun sell just front.. hey stig.. u selling car? sell me ur kit.. xD
thats raspy as!
I want it to sound like this:
http://www.youtube.com/watch?v=bDg8i...eature=related
thats johnny Fd's
what about this?
http://www.youtube.com/watch?v=RLuTUpsyTH4
Yeh that sounds mad. Resonator delete?
its a titanium pipe.. as apposed to the stainless pipes. :thumbsup:
the sound u get from the titanium pipe > anything u can get from a stainless.
Anyone got a shot of how it looks underneath our FDs? I'm trying to find a pic of the full exhaust work but can't find anything
would anyone be interested if i was going to let go my J's racing 304R muffler??
Just removed the big resonator...it's a bit too loud for me now but no rasp so it's alright
$5 and since youre asian, ill throw in some king springs
argh turns out to be too drony...
tomorrow i'm gonna replace the smaller resonator with a bottle type.
hopefully it'll sound better then :(
anyone got some FD sport rims they wanna off load?
Me if I can find something better :D
buy my SSR's!!! LOL!!!
Got pics? Where u located?
no pics. their in good nick.
you know the sizes and offsets right? 18x8 18x9 +38 205x40
what condition are your rims?
im in canbeera.
liquid23 might still have his sport wheels up for sale. though, he does live in WA.
what's ur price for ur SSRs? PM y0!
i want to buy new rims :(
lol u have a whole new car! id take a dc5r over a set of wheels :p
its track only though lol, iono might hock it off for street/track ep3r when i have some more money
