Thanks :) i will give it a go this week.
It seens abit far in. is there an easier way to get to it?
also on the right side. do I need to take off the intake?
Lol I just worked with the motor in the way, just get some pliers and maybe wire cutters and pry that metal clip off, then use zip ties or a large hose clamp to close it. For the right side you do have to take the intake off, but if you have a CAI then probs not
Hey guys,
Anyone know the part numbers for primary and secondary o2 sensors for our ep?
Primary o2 sensor OEM part number: 36531-PRB-A01 (number on the box, purchased from JDMYard)
Secondary o2 OEM part number (printed on the actual unit): NTK OHJ:562-H7 (Which proved to be quite difficult to find a OEM replacement)
I ended up getting an aftermarket Denso 234-4122 Oxygen Sensor, more info here http://www.ozhonda.com/forum/showthr...=1#post3301180 Post #12437
The secondary sensor, I wouldn't bother with changing it unless your actually getting a CEL specifically stating that it has malfunctioned or a similar error code.
Man, just took the ep3 for a spin tonight after 2 weeks sitting in the garage, and my gosh i love my car haha feels good to hit vtec again.
does anyone get surprise mods? some importers have no idea seriously.
cleaning the engine bay last night and found an engine torque damper, js racing tie rod, j's racing lower tie bar, some blue colored aftermarket rear camber arms that was not listed on the mods list when i bought it. how delightful.
thats some pretty cheap! might jump on it before our dollar gets worst, haha
I did, i thought i was running on a cheap aftermarket exhaust system,Quote:
but what i found was a spoon axle back n1 exhaust, unknown mid pipe + a high flow cat.
plus a couple yens in the cabin ;)
