i am on the verge of ginding my cusco a tad.
its slightly touching AC lines a bit, readjusted the best i could by loosening the two brackets so there is a slight gap. But my brakelines were slightly more annoying.
It is possible to adjust the installation of the ETD to reduce vibrations, i found at some stages vibration was quite bad and start up caused a shake through the car, adjusted slightly and it reduced it dramatically
Also found good clearance with the A/C lines etc in my euro :( they must all be slightly different as mentioned by aaron
bummer, i had to grind the side of the bracket cause it wouldnt have cleared the UR pulleys.
otherside on the chassis wasnt too bad only had to take precaution of the brakelines.
but yeh i'll see how it goes.
damn the ETD restricts you from removing the chassis to engine mount gounding wire cause its so phat.
unless you remove it or you have a slim socket extension.
btw aaron are you running the etd at the stiffest setting or softest?
Did some re-adjustments to ETD and made it a little softer and now the knocking sounds are gone. Unfortunately it isn't as responsive as before cos it's softer. It's really a trial and error exercise to get it right.
Definitely thinking about grinding the plate a little to clear the a/c lines, damn, taking it out is going to be a pain.
I'm thinking of fitting one of these to my car and I've got UR pulleys installed. What damper & brackets do I need to get to ensure it fits?
Yeah, time to break out the dremel. Just got a 2nd ingalls ETD kit just to replace the damper! About the same price compared to buying the damper unit on its own.
Dang that doesn't sound like an easy install at all. It'll take a fair bit of trial and error to get it right then.
