needs lows and lips. looks even higher cos you have non stock rims.
well today i went to get a quote to fix my side mirror part is about $75 for whole unpainted housing unpainted and honda service charging $132 for labour cost....seems a bit expensive just to change a side mirror...does any one know where else is a good place around liverpool area to get my side mirror change that dont cost too much?
anyone going meet today?
while i driving home from work i saw this white fd with type r body i think? that was speeding down hume highway heading towards lansvale around 3:00am today?is that anyone from here?
100% diy.
Just installed tein s tech, took 12 hours in 2 days. haha.
Well done Randy it feels good doesn't it !
now tell me you installed the top hats correctly ...Lol
oh yeah, there's a small bearings ball at the top hats isn't? good thing when i removed the shocks I pull it slowly otherwise I wouldnt find those bearing. hahaha.
Nah I'm talking bout the little triangle mark on top of the hat, the triangle should point at the motor ! but yeah if you had ball bearings popping out sounds like you had fun ! I've done my struts/shocks 3 times cause I stuffed up the first time, then I had knocking sound from one, so pulled em apart again and found I had stuffed the top hat. Third time swapped Eibach springs onto some new Tokico. Can do a strut spring change in about 30mins now !!! Lol
Stevil, can you please elaborate on the knocking sound you had when the strut wasn't triangled in?
