Yeah I wanted OEM but clearly they're not working out for my driving style..
Can you buy just a single Mugen mount?
Ridiculous exhaust cannon on this civic.
Don't know why some people do this......
http://img.tapatalk.com/d/12/09/10/7etemuda.jpg
ahahha you havent seen the one of my ek than hehehe
Using Valvoline Synpower 10w40 I think or maybe it was 5w40...
I'm just not sure why my oil pressure suddenly drops from what used to be average 28psi to around 21 psi idle now... i've been using the same oil ever since I got the car. Oil levels are fine, and I don't think there's any leaks. At 3k rpm it's around 65-70psi
The only think i can think of is that, I recently installed a water temp gauge, and i've tapped into the oil pressure gauge to power it... maybe it's robbing some power off it? But then, i've seen people with multiple gauges all connected parallel tho. :/
Don't think it would be a power issue but I guess you can disconnect your water temp gauge and see what happens.
What set of gauges are you using? I'm using a greddy informeter touch.
What is your exact idle temperature? Unless your water temp sensor has caused some impedence in the flow of your coolant. For our K20A, the oil is water-cooled at the oil filter section. From that, it can reduce the cooling efficiency of engine oil and therefore running at a higher temp. By running a higher temp, this can thin out your oil which leads to lower oil pressure.
Maybe some other factors to consider:
-How long have you been running this round of oil?
-Size of oil filter
-Ambient temperature
-Coolant level.
FYI, Honda service manual states 0.7 bar or 10psi minimum at 80 degree for inspection.
