No
Char
no, you need a turbo manifold specifically for a D16.
i was at just jap yesterday and saw the cast iron manifold there it looks good and if i didnt have a manifold i would just run with that :)
the D-series cast iron manifolds are fine, will do the job fine for an internally stock engine. hell, ive even seen em on 300whp D's...
yep, and after a year of my hi boost setup, it cracked.
Hi boost. what was the psi?
i dont plan on running anything above 10
Ohh well if thats the case dont do a forged setup then....stick with a high comp stock internal setup.
luke ran 11PSI with stock map sensor.
I think the stock map sensor is limited to 1 Bar, which is about 12 or 14 PSI i can't rem.
The reason u've come up with 10PSI is cos most people limited it to 10psi to ensure that it is reliable and without issue
