****kk, me jelly bro.
Haha sorry for rubbing it in.. :) How long have u had ur ep3 for and has it been like that since u got it?
Mines got i/h/e as well and still good.. Did u have a look at spark plugs at least?
Injen/plm/tegiwa
Looking to upgrade to stainless steel brake lines, what would you guys recommend? HEL, Goodridge or SFS?
After a cold start, when shifting into second gear the car jerks abit, but also has this 'whirring' sound, like say the car jerks 3 times, it'll be like... 'whirr whirr whirrr' but once the car warms up its all smooth :S
Also during idle with the stereo off, i can hear this feint chattering sound, and when i put my clutch it for about a second or two it disappears... i've heard ot flywheel chatter when people install lightweight flywheels so could it be due to the lighter flywheel the jdm ep3 has? I've also noticed that if i put the car in reverse immediately after depressing the clutch there is a nasty grind, so i have to usually hold the clutch in for a second or two then it goes in smoothly :S
Thrust Bearing or Gearbox Bearing perhaps?
When the nasty grind happens, does it still go into gear fine or is it stubborn and feels like your clutch isn't disengaged properly to allow the change?
Hey does anyone know what the EPS light means? And my fuel thingy is broken, it's just empty and has the light on, anyone know how to fix this ?
