If you're on stock mounts then yeah there will be alot of wheel hop. The oem mounts are pretty weak on the ep3/dc5 chassis. Especially the drivers side. I felt a huge difference after my hasports 70a mounts
ohh i seee, i'll definately sort them out with the 3pcs mugen set or 5pcs hardrace. Thanks for your help!
Thanks to all who have commented, at least I know that I am not the only one getting this noise! Much relief!
I just emailed Exhaust Technology who made the exhaust to ask if they had any ideas. I thought too today something about the water hitting the exhaust making it cool under the car while it is still hot at the front but can't figure out how that would account to it smashing on the underside of the car?
I have been able to narrow it down that it starts when there is still water over the road, doesn't do it when it is just damp. It did it tonight as I pulled up to the lights and then when I stopped the noise stopped but then suddenly started doing it again.
I was also thinking it might be the old heat shield from the original exhaust being bent down when water was spraying all over it but again, the loud banging noise doesn't make sense, neither did my though about something to do with weird tread patterns on the tires flicking water onto the underside of the car. Very baffling! We have only just started to get rain here in SA after having nice weather but it is due to come in very wet from now on... And I have to drive the car daily for work.
Oh, I also forgot that it happens when the throttle is closed and the car is engine braking gets it going... and you can feel it through the floor.
I had always thought it could be my header hitting the subframe or something since its alot lighter than the stock cast iron header. It only happens at low rpm when the engine vibrates the most I guess
It sounds like torture though! And has only done it since I changed my exhaust and that is only cat back.
Yep, if u want to keep the feeling close to stock then get mugen mounts. Mugen come in set of 3 so I got rear hasport mount as well. Not much vibration in the cabin.
yea my old car used to have hardrace, little vibration but well worth it now that i've tried without them lols.
Also my first ep3 had a problem starting up in the cold where it made a horrible loud grinding sound sometimes, and now my second ep3 does it too.. lols anyone had this problem?
After some research it might be the starter motor grinding against the flywheel but yea, not sure.
has anyone solved it without buying a whole new starter motor =[?
Hey guys, so i've been tossing up between the FN2 and EP3. only thing i like more about the fn2 is interior (seats and cluster), but i can live with the ep3 and also prefer the double din slot.
just wondering if anyone knows anything about this ep3 in melb, had B16TYM plates on it for a while. im going to have a look at it tmr. and considering the high kms, what do you think is a reasonable price?
http://www.ozhonda.com/forum/showthr...ite-EP3-Type-R
