These DO NOT fit 06 Euros. Just wasted money buying these today. The drivers side for the 06 Euro needs to be 6.5mm; 7.5mm ones dont fit.
I've gone thru 2 setsof replacement rubbers, they don't seem to fit or work very well, so I've given up and just ebay'd a new set of wipers off eBay, so far they worked pretty well. And it only cost $25 or something(http://item.mobileweb.ebay.com.au/vi...d=320671415702)
Go to repco I got 710mm for $4 and worked perfectly dont buy the ones from the pack you can get them in singles. I know they are diff widths too one is 8mm the other is 6mm not sure which side is which
I've gone through this thread a couple of times but am a little confused...
I have a 2006 accord euro. Where can I get aftermarket wiper blades which fit my car? Just the rubber inserts...
Thanks!
Hi Guys
I have a V6 Honda Accord Luxury 2008 - What wiper size will I need and other than OEM where else can I purchase from?
Cheers
Just want to add. I've put on my Bosch Aero Twin blades on, and they work great. Only thing is they seem to be a bit taller than OEM. What this means is while with the OEM blades, they stay low and aren't visible above the bonnet line, the Bosch ones are. Not so good for aerodynamics then.
I went to autobarns to ask about which ones i needed, they said we hondas need like 7-7.5 inches or something, i dont remember if it was inches or cm but yeah they said hondas decided to have different size which makes it alot harder haha
I buy mine from Supercheap Auto: Tridon MCP2428-2 Wiper Refills for the Pre-FL 05 Euro.
I use Tridon Flexblade on my wife's CU2.. they work really well.. no squeaks, no streaks.
