i always thought it was 1 bar
well correct me if im wrong, but arent the honda MAP sensors 1 bar? just because the MAP is 1bar, doesnt mean it can hold 1 bar of boost. a 2.5bar holds about 25psi...
nah 1 bar is 14.7PSi apparently
im only gunna be running 10psi max for starters so i'll keep the stock MAP sensor. A question on the downpipes on ebay for the D16 civics, are they really bad quality stuff or would it be sufficient for my build? Would i be better off getting one made..
they may be a hit or miss, you never know until you fit the product/item. try it & if it doesnt happen, just get one made up...
has anyone ran 12:1 cr d16s with stock ecu??
ive got this setup atm and im nearly ready to run but i need to find out if the stock ecu will b ok
It should be fine to start it up and let it idle, I wouldnt go driving it around though
