will it die anytime soon?
Just check your oil colour (under cap and in dip stick).
Check your coolant level/colour.
Get a compression test to see if the rings a stuffed.
What oil are you using? Brand, grade and full/semi-synth or mineral?
Such good advice from ozhonda.
Grey smoke is usually caused by the car overfueling (too much fuel burning) Could be caused by several things (poor ignition,vacuum leaks, stuck injector are a few examples).
Start by replacing your ignition leads if you haven't in the past few years, and a new set of plugs while you're at it.
I didn't read what car you have, but if the map sensor doesn't bolt to the throttle body on yours (obd0) then check the vacuum line between the intake manifold and the map sensor which is on the firewall on OBD0 cars and is prone to causing a rich burn.
had a free dyno run today thanks to a friend pulled 67.8kw with a auto d16a8 with i/h/e what do you guys think isnt it a bit low ?
thats what im thinking but the guy at the dyno said id make alot more if the car was manual
D16 should be 65-75 depending on mods/dyno.
B16a IMO 85-95. Below 80 I would be seriously asking questions.
Yeap.
