yonas had stock head IIRC
Everyone a simple way to understant to make light of what toda is saying..
If you own or have access to a coppy of nfs underground 2 try this.
1. build a supra 100 percent.
2. then go to tune.
3. peak everything to do with power right up last bar on tuning the highest (turbo and engine)
4. run on the dyno and look at the graph. (high power+torque in high rpm range)
5. test it on the quater mile, take not of your time.
Now start again but with do all of the above but with step 3 and 4 do this
3. try and run the power up from the 1st bar to a level and try and keep it as flat as possible.
4. dyno (your power and torque will be lower. but the power and torque should not tapper off and will be very flat)
when you do you quater you will realise you have done a faster time much easier. but you will probably have a slower mph, maybe 10+. this is because the car 2 isnt designed for higher speed but getting up to a high speed faster then car 1 and the quicker and more time you can spend at a higher speed then car 1 helps you cover more distance faster
http://www.ozhonda.com/forum/showthr...9kw#post884576
A 3 angle valve job + CTR cams etc is hardly a stock head. I still also have some doubt around not being polished but you can have the benefit of the doubt.
Not bagging you or anything but the reality of getting this much power from a 1.6 needs to be clarified.
um, what honda leaves the factory without a 3 angle valve job?
and e240 - the "power" you talk of is only a dyno number... on a "happy happy joy joy" dyno...
does that clarify it for you?
Tinky, so you're saying that the 119kw is not real? Then why keep emphasizing it in a number of posts?
Anyway, Toda's dyno have seen a number of B16as for its reading to be compared across B16as. So when a claim is done to have 119kws on a stock block :rolleyes: when other standard B16As (and tuned) on the same Dyno have done far less, you can't say that claim is just a "happy happy joy joy" claim. Especially not when you're claiming bragging rights with it.
i got 120kW on the same dyno (B20VTEC), i ran 14.5 @ 95mph on same drag strip.
seems to be fairly consistent?
what are these other standard B16A's you speak of? do they make 100kW?
which ones have I/H/E ITR IM & TB and CTR cams + springs and Hondata?
cant find ANY posts in this thread mentioning B16A's tuned on Toda Au's dyno... except EG5's one...
care to point them out?
