Nice to see it come together after all your hard work Dave, let me know how it goes on the weekend bud. ; )
no worries mate, i am guessing people could contact you regarding the acquistion of a decent machinist service?
Yes they sure will, we will have a full machining, cnc cylinder head and balancing service available to all shortly, just in the process of locking in a premises at the moment, whilst its been a slow set-up, rather do it right once! ; )
subscribed
again.
There are alot of B20's out there in Australia surely more people have questions about them.
You bored mate! hahaha
Will call you today too, WOT at the moment!
I'm about to drop a b18 head and b20 bottom in my ek sometime this month. Just wondering which arp head studs do I use?
Also I've purchased skunk 2 throttle body, intake mani and a full fujitsubo exhaust from headers to the exhaust. Wondering if there are any other cheapish parts I can buy before tuning to make it worth it.
What are you doing regarding gearing?
Sorry, this is my first time going this far into modifying a car. I haven't looked into gearing so I have no clue. Do you mean the gearbox? If you do then I have the normal gli box
A Dseries box?
Oh, just did a quick google and realised its engine based not chassis. I have a b16 conversion in my gli. So I have the b16a2 box ATM.
I was going to say lol. Nice, the ratios in that are fairly good
So gearbox wise I should be fine? I'm not planning to do anything else after the tune. Mostly for street use. Once my brothers car is complete I may occasionally hit the track with him.
Can I just use the arp b18 head studs?
How much would a decent lsd cost? If its in eBay could you link it? I have no idea what to search lol
any did a oil catch can on the b20,,,having some probs
What are you having problems with?
There is more than one way to do it, the easiest way is using the rear ports off the block - you will need to buy the fittings or some people go to the effort of welding bungs on the rocker cover, just make sure they are baffled from behind.
that's the way am going as well but,, i got only 2 fittings in the kit but now theres a hole on the other side as well where the black stock catch can was ??? looking at couple of pics on the net seems i need a Welsh plug of some kind
here is the kind of bung you need:
http://www.ebay.com/itm/b-series-b18...-/300708948948
and am guessing i cant buy that separate ??
thxs guys
Have a search around, some companies do sell it seperate.
Got a vernier? Use a welch plug.
Buy it at any auto store.
found a couple but they look like a alloy bung with 2 small seals on it ,,i wanna make sure it doesn't come out,,,,welsh plug FTW
It won't come out if it's the right sized Welch plug.
Quick google search;
http://honda-tech.com/showthread.php?t=729080
you wouldn't have any pics of your setup by any chance andrew
thxs heaps alex
and the 2 port that has been blocked off in the pics what else can be done to them ???
have a look at the Energy Dynamics (EnDyn) Breather Kit
comes with everything you need to fit it.
http://www.theoldone.com/components/...eather-Kit.jpg
or alternatively, you can source the parts individually.
I am running this kit but my mate and I managed to make the same thing for cheaper using bits and pieces. Either way works great and reduces oil usage.
What do you mean? If mean the black fittings with no hoses in them they go to a breather tank like the one above - take note that the breather on that is a defect as it's venting to atmosphere, if you want it to be "legal" it has to be plumbed back. (it's in that kit but that endyn kit is pretty expensive and his really slow to ship)
these ones
They are deleted coolant lines, I don't run a heater or oem oil heat exchanger. Nothing to do with breather.
The red circle on the left is one of the breather ports.
My setup uses prelude fittings out of the back of the block, and push on hose like what you get with the endyn kit
http://farm8.staticflickr.com/7253/7...12513ca8_c.jpg
nice thxs heaps alex
b20 swap done yesterday car runs amazing ,,,now to the head which one b16 or b18 or even work the b20 head ???
How would a b20 go behind an audm ys1 from a da9?
the b20 ecu from the half cut CRV
what sort of prices am i looking for a b18 or a b16 head
B18c7 / b18Cr head about $400-$600 without cams. If you could get your hands on a b16a head much cheaper then I would recommend you get it if you're going to be upgrading your valvetrain I.e valves, springs, retainers etc if keeping your head stock just go for the b18 head. :)
okay ,,so the b20 head is not going to get me anywhere even if i work it out as in porting,,valves, guides,,springs etc
always do :)
B20 head isn't worth all that work just hold out until you get a vtec head. On firesport someone's selling a b18cr/c7 head for 1.5k nego if you're interested B18c head with buddyclub valves, TODA valve springs and titanium portflow retainers. all brand new parts with a second hand port and polished head. does not include cams.
if you're not changing the pistons it may be wise to run a B18C2 head with a skim, should get you close to 10:1. 9.2:1 is a bit low imo.
Run skunk2/blox intake manifold if you want it to be similar to an ITR head. I think you'd benefit from the compression increase more than having slightly better flow.
i see
Are you planning on freshening up the bottom block or are you just gonna slap the vtec head on ? If you're gonna freshen it up run the RS ITR pistons 11.5:1 ( CHR1S's recommendation :) ) Not too bad in price and they have similar characteristics to Oem ITR ones. Then that way you can go for a b18 head. High comp ftw.
B18c head with buddyclub valves, TODA valve springs and titanium portflow retainers. all brand new parts with a second hand port and polished head. does not include cams Price:$1500 neg
what do you think on that
Honestly that's not bad considering everything is basically done for you, he is nego on prices so try throw him a offer. If you're gonna be turboing it then the RS machines are not for you sonce theyre cast style pistons. You're looking to go down the forge route onviously which will set you back a bit more ... All comes down to what your future plans are really. Yeah of course NA's need high comp, but in the end most of your power is from the head. Get a nice set of cams to go with that b18c head like skunk2, toda or m22x cams ( another one of chr1s's recommendations :) ) and you should be producing satisfying numbers after the tune
thxs heaps to you and chris
next problem,,,,car dropping in revs when i reach between 100 to 140 ,,,feels like a fuel cut or rev limiter but not sure
suspects :
1. spark plug is bkr6eix -11 instead of the normal zfr6 stuff
2. change leads to a 10.2 mm
3. iacv
4. tps
anyone ?
Could you be more specific about it dropping in revs? If you can hear it drop, and feel it drop I'm assuming it could be a clutch slip. When was the last time you changed your clutch?
clutch is new
Been driving my b18/b20 for about 4 months i was afraid to go past 6k rpm when i first got the engine and now im regularly pushing it to 8k rpm. Not one issue yet and the torque is heaps of fun.
whats peoples thoughts on b20's fuel consumption? with honda being green and efficient and all. for daily sub 3.5/4k rpm driving whats peoples thoughts on a stock high comp b20 vs a stock block and stock head b20 vtec?
both with the same boltons and stock internals/cr's 10.0 or 10.2 vtec (i guess intake mani/ tb would be specific but keep the headers/exhaust and intake arm/filter the same)
smaller ports/intake valves in the p75 head for better low rpm velocity and lower rpm powerband manifold, especially with 2l of displacement. swirl with the staggered primary and secondary lobes in the vtec head. and small bump in compression (i guess the increase in displacement would help with lower rpm velocity also...
i assume built b20v high comp pistons stockish non vtec lobes and associated work would have better km/l then stock.
all options tuned of course ;)
thoughts/experiences?
i imagine the stock r/s ratio would wear the rings/walls a little faster then a b16 at 8k, regardless of how well balanced ect the bottom end is.
dosent mean its gonna die in 5 thou klms though... what do you mean b18/b20 p72 head?
