Originally Posted by
Baby Face
			OK guys lets go off topic.
the Ap1 floaty feeling i get is when u break near the last moment before a turn (or in a turn, if u pussy out) then the weight shifts to the front since the front springs on the ap1 are softer then the rear by a lot! (02-04 models are slightly stiffer fronts but still softer than the rear).
so when u brake there is no weight on the back and it feels like flicking out.
so the answer is to keep power on so that the backwheels are keeping up (not dragging the gearbox/engine), we dont have these problems in FWD cars since the rear end just follows, but in the s2000 the backwheels can start doing the braking if ur foot is off the accelerator mid turn, it leads to lift off over steer (a very easy to achieve lift off oversteer). less experienced ppl will keep the car in a higher gear so the engine braking to the rear wheels is less, if ur good you can keep it in a lower gear and be ready to catch the power oversteer. your basically stuffed either way it wants to kick out at the limit.
