Not a proper one sorry but you basicly just drill 2 holes through 2 spare pin holes that are next to each other, then you drill out the centre of the 2 holes so it becomes one big oval shaped hole(hope that makes sense), you need to do it on the Male plug(cabin) and female plug(door) then pull the wire through. You could also add new pins in so you dont have to pull the wire through when you take the doors off but i wont be pulling them off often so ill leave it like that while i have it.
heres a pic i took of the plug and ive drawn where the wires are now in yellow and where i drilled in yellow.
http://i1220.photobucket.com/albums/.../IMAG1099c.jpg
The hole in the door is where the female end of the plug is meant to be but mine was out being drilled when i took the pic but gives you an idea of where it is.
http://i1220.photobucket.com/albums/...s/IMAG1100.jpg
