My clutch still has a slight squeak but the grease was like dark grey and the whole cylinder was covered in it! Just wondering if I need to replace or not...
How's ur clutch fluid reservoir ? Do u lose oil ?
I topped up barely anything now. And no, i didn't bleed it. I assumed that was only when you flush the system?
if its losing fluid its going somewhere, it's not like it "uses" fluid so to speak. so if it dropped to "Min" then it is leaking somewhere, most likely the master cylinder.
an easy to spot sign of a leaking master cylinder is seeing leaked fluid where the shaft connects to the clutch pedal inside the car, or on the firewall around the cylinder itself.
Right, I'll check that soon. So how long can I go on with it leaking?
***Official What did you do to your Integra today***
is now
***Official Diagnose my Integra today***
Got that lug out, wasn't even hard!
How u do it?
