I have an Aftermarket 2Din unit with usb cable running from the back of the HU. With mine, I routed the cable to the glovebox. Hope that helps..
Thanks for the heads up Cracker.
Ok thanks for the feedback guys.
Cool. One other thing, are there any suggestions on where to pick up a double din fascia? JB were quoting $200 for one.
hey guys
what is stock speakers in the front and rear of the FD1.
Can you guys confirm if its 6" in the front and 6.5" in the rear
Looking at upgrading the stock speakers and the headunit.
Also, whats ur experience with the type s/type s alpine range install on the FD? Fitments without any adjustments.
Thanks
Ask JB where the double din was made from. A few months ago a Jap one was around 180 and the thai one was either 150-160.
Prices might have changed as it was last year, and i know audio places sell them for even more then 200, so its probably a good price. Saves trying to import yourself.
I can confirm the fronts will fit 6.5" and most probably the rears. I currently have 6.5" and i remember another member stating he had some in the rears also.
I had mine installed, so most probably spacers were used but they don't need much adjustments or any screwing into the car body.
Im guessing your not going to amp the speakers? Type S should be fine then as anything above type R would be a waste if your not amping, but don't expect alot of improvements over the stock speakers.
There would be a difference but probably not that noticeable. Headunit amp just doesn't give enough power to hear a big difference.
There are even cases where the actual speakers sound worse then stock because of that. I forgot who but someone here has type s speakers, not sure which member but he has a fd1 also. Hopefully he might have a better answer for you.
