The lower VTEC point of the mild reflash is at 5000rpm.
Thanks tony1234, been looking forward to your impressions.
Can't wait to see 4 myself....:thumbsup:
So bottom line :
Seems like the mild flash is bang for buck?
Best thing i noticed about the Mild flash is the lower vtec, smoother take off and higher rev limit
atm my car as soon as it hits 6000rpm its straight onto redline, wild the mild flash i didnt hit the redline at all and had the car into the red line
Pretty good overall, pretty impressed with the top end of the extreme package though, went great
I'm not sure if it does and but that's what James said. He said that when the twin tails pipes were 3 inches (which it was in one his initial prototypes) they measured a lost of power in the top end. When they changed it to 2.5 inches it made more power. He mentioned something about volume and pressure but i don't remember what he said exactly.
BTW, i forgot to mention that the exhaust has a special type of lock joint for extra adjustment so you won't get that lopsided look with the twin pipes.
Hey Tony, my name's Jin. I was the owner of the test car. Sorry i didnt get to say bye. I thought you'd left then i saw you in my rearview.
dont forget to mention that the extreme kit and mild kit seem to fix that really touchy accelerator when you have the car rolling in first gear.
Ive got it on my car right now, and i was driving around all night. It got alot cooler at night.. and the car was alot more responsive.
You won't get any much benefit of 3 inch exhaust from I/H/E minor mods only with tuning. They have to go with "real extreme" mods. You have to combine it with aggressive cams combo and higher flow intake manifold, eg RBC or PRC to get the extra power out of 3 inch exhaust.
Single or dual exhaust, well dunno if there is any difference in dyno but single exhaust for sure will create more responsive feeling than dual.
If that’s the case why would Honda produce the standard Euro with two mufflers ? You think they really would do this to decrease a cars response on purpose; highly unlikely…not to mention a single exhaust on car designed for two mufflers looks dame ugly. As for you saying its more responsive, what evidence and back to back testing have you done to backup your statement or are you just pulling theories from your ass ?
Well I tried on my friend 00 accord 2.3 L did have twin exhaust and before he sold his car he swapped back to single exhaust which made noticeable difference in response, that's personal experience.
If you looking for any more proofs just use yahoo or google, dude or just do it and give us the feedback.
ALN correct in saying single gives better power... why do u think all race setups use single exhaust?
honda didnt go with the dual exhaust system for power! they went with it for looks and quietness...
Can you provide us with any proof or article to support it ?
what make you think euro k24 is more special engine compare with k20 that dual exhaust works better than single.
Have u ever think about those people that swap k24a engine to EG or EF or EK which fundamentally works the same and none of them used dual exhaust and still produced higher power figures in comparison to k20a due to higher displacement.
Well I'm not expert in this kinda technical stuff, but few of euro owners here are currently using single exhaust, well may be they could give you more feedback
well... and you can use ur logic why spoon, J's racing,5zigen, Amuse even bother to sell single exhaust if they already knew that dual works better on euro.
im no expert either... but in theory a single exhaust should have better flow characteristics... considering that to make it a dual first u need to split the piping, then you need to add in two more 90degree bends.... all of that adding back pressure and flow disturbences...
Yeah,hi Jin.thanks again for letting me drive your car with the extreme kit on it.Yes i did forget to mention that both reflashes seem to fix that really touchy accelerator when you have the car rolling in first gear.:thumbsup:I'll bet you had fun last night with your car.:p
is this reflash compatible with the euro?!?
http://www.hondata.com/reflash_tsx.html
Its for the US TSX not our AUS verison of the Euro, their different and not compatible.
A dual muffler has better muffling capacity because there is less air going through each muffler. But the two 90 degree bends before each muffler means that the exhaust gas is slowed down significantly. Single muffler piping can run straight from the middle resonator, so has less restriction. The downside is that a larger amount of exhaust gas is going through 1 muffler and will be noisier. Honda went for a 2 muffler setup for the Euro for 2 reasons. It makes it look upmarket and is easier to keep quiet.
^^ also its aaron... everyone will agree :p
Hmm
..is that Sir Aaronng...
or
HRH Aaronng.......lol
No offence but....I am quite confused how you can equate or compare an Honda Accord Euro that was designed as a "family" car to a Nissan 350z or an RX-8 it does not compute as the Euro was never designed to be an sports car .....or an car that has a V6 engine (Aurion). The closest thing that you can compare the car to is an Toyota Camry or Audi A4 in body type and engine. Even to get compared to a sports car is doing well .....I would have thought the 350z and the RX would have been compared more to the S2000.
Now with the whole argument with Dual verses Single if you had been listening in the presentation....... JTune tested both systems with Single and Dual Systems they did extensive testing ....trust me I know. The car performed better with the system that is the end product (Dual) than that with a straight through. They have proof from dyno results. Besides that as was said by some one else the car was designed with dual tips as it suits the car much better. A single exhaust outlet does not look that good... you have one cutout that is empty on the side that looks strange if does not have a second exhaust. That was also considered.
The Exhaust is a 3 inch System to the just before the petrol tank then splits into two 2.5 inch exhaust pipes into the rear mufflers. Again this was fully tested to get the best results...... They tested this over 2.5 years so I think they know what they are doing.
Also the TSX flash and the Euro flash are from the same source originally but altered to meet Australian specs with some additional tuning from James.
The Euro can outperform the V6 Camry (115kw) and the Audi A4 2.0 (103kw) even in stock form. Why would you spend $5000 to outperform cars that you can already outperform in stock form? All I'm trying to say is that while the extreme package does improve power noticably compared to stock, it's simply not as quick as I expected. The extreme Euro is supposed to do the 1/4 mile in 14.8ish seconds at 160km/h which is in line with the 350z and RX-8 but it didn't feel nearly as quick as the two. In terms of acceleration it felt closer to the Aurion Sportivo I drive at work (though not as torquey). I don't think there's anything wrong with comparing a stock V6 with a highly modded 4 cylinder car.
You are losing the point I am afraid that I am trying to make. I am talking about cars that are normally in the same class and size of engine. Since your comment is that it is "nearly as quick" then I would say ...not bad for a 2.4 litre NA motor that normally on average might have max 110KW at the wheels (notice I said on average folks) The rotary I can not say much about since except that it is very quick and in comparrison of a motor well they are different being based on a low friction Rotary Motor with 1300CC but 170KW of power ...the 350Z is a Standard Engine 3.5L V6 @ 228.18KW @6800 engine .. but both built as sports cars......even if you compare the Aurion... 200KW V6 Engine..... if you compare the two as your are and you say it's close.. and also compare it to an Aurion at 200KW .... Then Jtune has done a great job...... even to be comparible to this car in perfomance.
It is a shame you did not get to drive it.... you should have asked the owner he let Tony drive it and you would have realised what is fully like :D
Also you gotta remember it was a 30 degree day and humid which also affects performance....
I think your all crazy trying to compare cars on 30 degree days that’s an unfair disadvantage. I would really like to hear how the car responds at night time when the outside air is cold. We all know every car is very sluggish in the heat, but if it impresses you in the heat imagine what it will be like when it’s cold. Out here in WA our cars are always slow during the day and totally different at night in fact a lot of tuners only tune after hours when it cools down.
Some cars are worse than others - in my experience the Euro is very different in hot weather compared to crisp weather. It is like a totally different car. Compare that to my SS and the difference is not that much in hot and cold. 3 years ago I started a thread about my Euro having a personality disorder - it is true!
I don't really want to debate this any further as I think it's pointless. But to avoid further confusion, I mean that the RX-8 and 350z (not the revised model with 228kw) both feel a lot quicker than the Euro with the extreme package. The Aurion has 200kw but keep in mind that it's also a massive 240kg heavier than the Euro. Jtune has done a good job designing and manufacturing the hardware with the ECU to match it but in terms of raw performance it didn't quite meet my expectations.
I might have a very different impression if I had the car for a full day in winter but all I'm posting is my impressions of being a passenger in the car for a very short period of time.
350Z only have around 155kw atw...
ill be topping that number very soon! lol
You answered yourself. The RX-8 and 350z have better power to weight ratios than the Euro, while the Aurion has an additional 60kW but is only 240kg heavier, also giving it a better power to weight ratio. That is why the Euro feels slower than these 3 cars, because it is.
The Euro feels slower than the RX-8 and 350z but feels about the same as the Aurion (but not as torquey). Power to weight ratio is not a reliable way to determine how fast cars are. There are many other factors that come into play. Anyways I've said what I needed to say so I won't contribute anymore.
So the only reason the Euro is slow is because it’s a heavy large boat and not a race car.
I brought my euro coz of the looks ;) then I wanted it to go faster :D
Actually read these so Aarong you are wrong based on these articles. But this of course is based on the US model.
http://www.roadandtrack.com/article....&page_number=1
http://www.roadandtrack.com/article....ber=2&preview=
http://www.caranddriver.com/article....&page_number=1
So peekay how does the Euro drive in cooler conditions with JTune Extreme package ?
Well just let me say I hope you have good tyres....... Also a lot of effort went it to this the car was even dynoed at 4:00 am in the morning to be certain for the sole reason of having intake tempatures at a stable cold level.. safe for the car also at lower temps the car made another 5KWS at the wheels.....
i made 130kw/atw in 6degree outside temp :p
ive devised for stages of mods... stage 1 is nearly complete! stage two will be done before christmas, and 3/4 before winter next year... by then itll be -4degrees in canberra, so my dyno will kick ass! lol
competition is gooooood :thumbsup:
lol but i didnt think 50degree cam was good for the k24? isnt the piston to valve clearance way tooo close for that? hence why on the k24 the VTC only has 25degrees of change, but the k20 has 50?
im gonna grind mine out to about 40-45degrees of VTC :D
If Peekay comes to a Dyno day I organise, he will blow the competition away... *thinks of a way to ban him* heeheeheeheehee.....
whats peekay got atw now?
hmmmm your all just bluffing :p lol jokes
i just got back from my mates place.
i tell you what, the euro drives so nicely in cooler weather. i was impressed at saturdays demo. Cooler temperature makes a noticeable difference. Top end pulls and pulls and pulls.
Im enjoying the extreme kit so much.. i don't want to give it back!
Great write up sodaz
personally, after its all said and done, i wouldnt fork out 4K or however much it costs for an extreme package, let alone for a mild ECO reflash.
but nevertheless, its impressive and also a shock that Jtune finally after all this time released the package. many euro owners would've thought that the day would never come....but i guess u cant rush these things
that being said, personally i'd prefer a euro being a luxury cruiser rather than a sports car wannabe. each to their own
As much as i love my Euro brutha's here in the ACT, On the EXACT SAME dyno that EuroACT used, my car got 86kw at the wheels! So theres some seriously screwed up shit going on at that dyno. It was about 20c when i did it. My cars newer and has only 35 000km to boot.
Im actually looking for another ACT dyno thats decent for a run with my I/H plus Hondata.
Forget all that, why is there so few reviews from SAT? Im keen to hear more about the mild flash given Ive already pre - ordered.
hm, well i was on sat, but i came late and left early (had stuff to do) but yer, i didnt get to go in the cars i just really heard the exhaust (which imho is too big/thick, looks too big for the euro) and see the products which do look good and shiny =P
so yer i dont have any real impressions of the products really hehe
Didn't anyone take any photos at all?
ill probably be taking some photos tomorrow.
everything will be off wednesday morning.
haha, i know my car's going to feel so slow.
Ill be at the JDMST meet tomorrow if you guys wanna have a last look at it.
Here are some pics.http://img409.imageshack.us/my.php?i...2007002bt2.jpg
hhttp://img519.imageshack.us/my.php?image=17112007003xt6.jpg
http://img409.imageshack.us/my.php?i...2007004ao3.jpg
hhttp://img442.imageshack.us/my.php?image=17112007001yw6.jpg
http://img442.imageshack.us/my.php?i...2007002bt2.jpg
Sorry some didn't upload.Disregard the 3rd.link.:o.I'll try again.
Thanks for the pics tony1234, I think that's my system hangin' on da wall....
Xiang, would appreciate some pics from the back to see the size of the tips, and under the bonnet would be nice.....
Thanks everyone for the feedback, great to finally have it all happening.
Many of us thought it would never eventuate....some dissapointed and some not, depending on the individuals expectations I suppose.
Anyway, looking forward to personally driving with the mods........
Thanks again all 4 your feedback
