Need to change back to my stock Fly wheel as well...
Now that I'm boosted the lightweight one is losing me momentum
Id say not worry about it man. Its giveing you gains at low rpm.. but you just loose out if your "granny shiftin". Practice driving more with your setup as is and getting your shifts as fast as possible. You will loose RPM faster with a light flywheel vs a stock one on shifts.
if you got the guts to be a bit mean on your box give flat shiftin a go!
Ok Guys
Setup Changed thus far
Completed:
New Plugs and re-gapped
New Fuel Pump
MBC Installed
Stock Wing Ready for D day install
Yet to do:
Adjust my Coilovers to raise the back up a bit to force the weight to the front wheels.
New Tyres ( Won’t be done till after I get back from Thailand)
with the coil overs get ones with adjustable hardness. u wont have to raise the back up, just make it harder in the rear
when i adjusted my coil overs in 16 adjustable (16 being hardest) i set fronts at 9 and rears at 13. might be wrong but seemed to work well (mind u i never took it to the strip with the adjustable coil overs)
ps ur all a bunch of whingers....
however with my crap as luanch's in my turbo d, my first time i was hitting the same times and hitting 95-96mph.....
that was on 5 psi with 22kw's less??? i never timed it on 10 but it was def alot quicker round town....
hmmm take it out again after u done ur small amount of work, have some more practise and see if u can pull that sucker into the 13 second braket which it should be capable of with that power...
well mine were same coil overs on urs with the ride hight set on the lowest setting hehehe
