This...
http://i.imgur.com/uXcPy.jpg
to
This
http://i.imgur.com/7X9Ob.jpg
This...
to
This
in my opinion, ek9 tail lights would look the best on your car, but i don't think the dark altezza lights would look bad at all. i would go dark over chrome.
Well, one of the best suggestions that I've heard is the bolt that holds your back seat down.
I've used one of the bolts that holds on my tail lights, and it's worked well enough.
Do you know how to disassemble your back end? (All plastic moulding, boot floor, spare tire and back seats)
*edit*
I just headed outside and had another look, and here are the other good spots I saw.
Where your spare tyre goes, there is a bracket that the long bolt you use to hold it in place goes.
There are pre-threaded holes that'll be solidly welded in place under the little plastic discs 300mm on each side of your boot latch. I believe these holes are intended for anchoring child seats to.
Hey man.. i appreciate you going out of your way to have a look.
ATM mine is bolted next to the boot latch. .thats what I was talking about.. but the position of the sub and the amp (amp is mounted ontop of sub)... makes the grounding cable from the latch to the sub look messy because its in the middle of the boot.. so ill have a peak at where the rear seats bolt in and bolt it to there as its probs a better place as its way more hidden
cheers!
Sounds good. You know how to pull out the upright parts of the back seat? It makes accessing that area a ton easier.
Btw, I'll be rebuilding my boot floor to house a full size alloy spare soon, and when I move my amp around again for that, I think I'll use those ones on the back of the car. Do you know the spots I'm talking about? They're not right next to the latch, but like I said, 30cm on each side. I'd take a photo, but I couldn't be bothered working out how to post images. ;)
http://photobucket.com/
... you can work it out from there :thumbsup:
Took the roof out of my EK shell today, who wants a sunroof roof :cool:
Pics ? ^^^
Diy ek9 headlights + Diy pod filter box no pics.
http://i40.tinypic.com/34uh3.jpg
just lowered my car on kmacs with KYB front shocks and GAB damper adjustable rear shocks edit pics tmrw when day light
Just wondering where the best place to find the parts to do a facelift conversion would be? Just ebay the bumper, hood, quarter panels, lights... Do you have to change subframe?
