OK
I have replaced Coil and have Spark Now
I replaced Spark Plugs
Checked Leads and double check the go to correct place
I have Fuel I can smell it out the exhaust pipe,
I have Timming Belt Still Checked that as well
I reset the ECU
Its not starting Can anyone think of anything else to do please help.
Im running out of ideas.
Anyway to get s Engine Check code to see the problem ?
what else could it be ahhhhhhhhhhhh
OK this is what happen
The car started to Misfire then Died
Checked for Sparks Didnt get anything
Replaced the Coil
Now we have sparks but not starting ahhhhhhhh soo annoying
after all that, you might of flooded the engine with fuel? is that even possible? thats why it might now start now.
just food for thought.
is the rotor button turning when you crank the engine ??
are there any codes in the ECU
Rotor is spinning,
How do i get codes from ECU ?
I know this might sound a bit backyard....
If you have a mate that has b series that is running try swaping suspect parts eg. like whole dizzy. If it starts something in dizzy and start swaping dizzy internals to narrow it down.
Check your alarm as well if you have one sometimes they have multiple stage imobilisers.
Cheers
EGJOE
ey man, try the main relay if you haven't done so already,
http://www.ozhonda.com/forum/showthread.php?t=31796
sounds like there isnt any compression ??
is that normal ?
did you try push starting it , ? eg joe got pretty good idea there.
U fixed the spark problem but you probably messed up the leads
http://images.google.com.au/imgres?i...%3Den%26sa%3DN
spark plugs are fine... still not starting
do you get a strong spark, is a waek pissy spark ??
could still be the ICM
