Green block gangster
Array
DIY Main PGMFI Relay repair
Aim: To get the car running again
Required: 10mm socket, wratchet to suit, solder, solering iron, flat head screw driver.
Steps: not many
so your car starts fine, but after some driving it will stall and wont restart, or restart then stall again, this can be symptoms of the Main PGMFI Relay at fault, as well as other things like coil, ICM, but since the main relay is so easy to fix, why not start there.
A good sign of the relay at fault is you might not hear the fuel pump prime for 5 seconds when you 1st turn on the IGN, ( it can still prime if the relay is faulty )
also low or no fuel pressure.
STEP 1: Locate the main PGMFI relay, you will find it under the dash, commonly the RHS but dont be fooled, lots of modles have them on the LHS, CRV for example you have to remove the glove box. the relay looks like this
STEP 2: remove the relay, there will be one bolt with a 10mm head. unplug the wiring harness.
Step 3: open the main relay, use a flat head screw driver to pry it open, do this evenly from both sides.
Step 4: look for the dry solder joint, if you cant see it just reflow the solder on all the joins, add solder but not to much, allow the solder to melt and bond to the components. reflow the solder on every join, only takes 5 minutes.
STEP 5: reasmeble the relay in revers to disasembly and refit to the vehicle.
thats it !!!
if your unsure of the Main PGMFI Relay location for your vehicle, just reply and im sure someone or myself will tell you.
if you have fixed your relay and still have problems of not starting, start looking at your disributor, eg ICM, Coil. also the ignition switch
always a comprehensive read...
good job
good read
i know where to start if my car stalls now.
Just did this recently myself. Car starts perfectly now.
Great write up John... again
 Originally Posted by z3lda
ey, was drivin a honda city before...
felt like the biggest poofter in the world..LOL
IMO you can DIY drill a small amount of uniform holes around the enclosure to prevent old relays heating up/dissipate the heat in future too
nice work again there John!
+PQ point!
nice, u have the skills to pay the bills alright
get the pics up again please
Array
can i just buy a new one? used one? from honda?
for dc2.
THANKS
hey does anyone know where the relay is located on a da9 teggy?
Array
its been a while, But I recon its behind the glovebox, more to the left of the car.
