holy shit dude, that bolts only supposed to be like 40lbf-ft
good old noob backyard mechanics, it aint tight until it stops moving hahaha, every single bolt on a car has a specific torque spec, yes it would be a pain in the ass to follow but for the more major bolts ie you suspension, wouldnt hurt asking
anyway quick tip for everyone installing LCA's new or reinstalling old, do not tighten the bolts on the control arm completely while jacked up in the air, do it so its firm, bring the car down, and tightening completely. By doing this you are going to prevent premature bush wear. If you tighten it completely while car is jacked up ie no load on vehicle - hence no load on the control arms, and bring them down, the bushes will twist as the controls arms change angle (there is no slack between the bush or bolt for them to rotate to a sensible position to coresspond with the angle while the cars load is on them), so your bushes will constantly be twisted / have twisting force on them even while your car is sitting still, causing premature failure/fatigue
markojek1 is right, no tightening the suspension bolts while in the air
if your cars too low to crawl under then you could probably jack up the lca to approx normal ride height and tighten it up
