no remove, sell
or get the motor rebuilt with forged internals, stage 3 cams, I/H/E ITB's perhaps???
then use your VTEC controller :)
even then you dnt need it because an aftermarket computer should control it LOL
ok cool u guys have convinced me!
I had a look and its spliced into the wires running to the ecu. If i simply snip them from the stock wiring, will i be able to start my car??
I also have an immoboliser, its a pain in the ass to start.
Immoboliser has to be pressed with special prong tool twice, then turn on ignition, wait for apexi to load, then start the car.
will i experience problems if i take apexi out?
cheers.
BTW thanks for all the help so far guys. Riviera to answer your questions - yes vtec is engaging, at 5500 according to apexi.
Ok so by basically everyones input - apexi vtec controller is useless. Why do people get them then? is it only for really worked engines? Also how does the vtec controller hinder performance.....?
Also, once i get it running off stock ecu, do plugs leads timing all small things etc, can i get it tuned somewhere locally to get it runnin optimally? will it make a difference?
ill check build date, numbers etc tomorrow and let you all know.
I appreciate all the help so far guys thanks heaps keep the input coming!
:D
make sure you come over to crxaustralia to while your at it.
Thanks Luke.
Just wondering if anyone knows the answer to this:
ok cool u guys have convinced me to take out my vtec controller!
and also how much are apexi's worth these days?
does it just say apexi vtec controller?
Or does it say apexi vafc???
