I have a feeling you haven't attempted to build.
Please dont call me the village idiot, when your post make no sense.
The cost of making 300+ kfrank?
The weakness isn't in the rods, its the rod bolt that will hit its limit 1st on the k24. There a heaps more things that will go wrong before your stock rod shits itself.
And your cheaper alternative, is the more expensive way. DO NOT BUY ANOTHER K24 & JUST SLAP IT ON. It will slap you in the face when you bounce of the limiter.
Reason for stock comp k24a3 - Boost. Same as E85 explanation.
Reason for stock CU2 Piston - Do you even know its compression? TSX would be even better. CU2 will be more readily available in aus.
Also E85 is not worth it unless you have gone all out NA and still requiring more. Cost for performance gained is minimal. Boost is where you really see the benefit. You can run more boost before hitting the detonation threshold.
He already has 2 engines. Just rebuild to basic specs to best you can afford. Speak to an engine builder. He will clear the questions you have, can be done for under 5k if things go your way. Maybe remove/install and disassemble motor yourself. Get a shop to do all machining balancing and assembling.
I would be buying majority of the parts from overseas to save on cost. Aussie Vendors sometimes want too much.
Thank you.
