Originally Posted by
lokets
What a rip-off, Honda not willing to sell the oil. Try another dealership/spares department. I got my 4L CVT only oil at $81 in Springwood Honda, QLD. No questions asked. You are in Sydney, yes, why not ask the friendly folks here, I'm sure there are lots of Sydney CVT Jazz owners & some do buy their Honda oils for replacement, etc.
You can opt for the free test drive offered but if they don't want to sell you the oil, they would also want to charge you heaps for service fees - for potentially not a CVT start clutch failure. It would be to their interests to offer their opinion to you without you first trying to fix this on your own.
I did not notice any reduction in noise after changing to the CVT only fluid. As you said, the car itself is quite quiet. The most amount of noise comes from the air-con belt/drive. That overrides all other noise.
To change the oil, you unplug the drain plug on the right side of the car at the bottom. Then, put back the plug and pour the CVT fluid at the top - after removing dipstick (you will need a long tube to guide the fluid down as the hole is not easily reached). It can be done within 1 hour but dispose the fluid the responsible way. For the unplugging process, you do not need a car ramp, there should be just sufficient space under the car to do the job without the need to jack it up - well I did not.
BTW, out of curiosity, is your Jazz a 1.5 or 1.3? And is your Jazz a Thailand made Jazz? I'm just wondering the quality of transmission from Thailand Jazz now as mine is made in Japan and my Jazz's problem came up in 125K km (pretty long) and yours at only 60K km (too short).
