no drilling on ek and em1 required..
u cant exactly drill the holes for the EK as from memeory the ek aSR block lower bolt is threaded
for the ek beaks kit u need to drill into the subframe, no choice there
ok just to clear up for me cause i'm a bit slow, so if i have ek4 endlinks i can use those to put a ek9 sway no probs? is this the same for the brackets that hold it on the subframe?
if you get a complete ek9 sway bar with the "D" shape mounting brackets that's all you need. Cause ek9 and ek4 end links are the same. You only need to use your ek4 endlinks if you can only get a ITR sway bar.
Of course you'll need the ASR brace to mount either.
ok cool, so ek4 endlinks i can use, but not the d shape mounting brackets. i should use the ones that come with the ek9 sway.
can you use the ek4 bolts from the d mounts for the ek9 d mounts? i'm only getting the sway and d mounts, no endlinks.
ASR kit should have all the bolts you need.
for the ITR sway, don't you need adaptors so you can use the ek endlinks? as recommended by ASR
bumping this thread up. what are the adaptors u need when putting EK4 endlinks on an ITR sway bar?
