hey guys,
another question, with the stock headunit what connectors are used to be plugged into it from the speakers?
Are they RCA connectors?
Thanks all.
hey guys,
Thanks all.
no... RCA dont carryamplified signals.
sorry... not into stock.... its either stock and you dont touch it or go all out....
I would probably use the ghetto method... cut and rewire, then use a heat shrink shealth to seal it.
Yeah, it's actually about ~50mm from the window and ~80mm from the bar.
Crapdaz, check out these two threads for what I did.
http://ozhonda.com/forum/showpost.ph...40&postcount=8
http://ozhonda.com/forum/showpost.ph...7&postcount=49
HTH
-Steve
I went a full rockford fosgate setup in mine
Fronts - http://www.rockfordfosgate.com/produ...n_US&p_status=
Rears - http://www.rockfordfosgate.com/produ...n_US&p_status=
I just carved out the actual door interior and mounted on that for the fronts and same as the rear.
got 2 alpine line out converters behind the standard deck
and ran the RCAs to the rear and got 2 amps
Subs - http://www.rockfordfosgate.com/produ...n_US&p_status=
Speakers - http://www.rockfordfosgate.com/produ...n_US&p_status=
and 2 12' RF subs in the RF box
and yeh a few people have seen mine and said it looks alright =D
if you want i can get some piccies
RF... used to like them, then I got poison by more exotic stuffs...
RF dont make amps like they used to... I heard maybe there are going back towards the old school era again.
this is my first setup.....
http://memimage.cardomain.com/member...58_19_full.jpg
