SOHC only has one cam, that combines both intake and exhaust?!?!
well the last vti system i saw used a sliding camshaft design with a progressive trapezoid shaped lobe. as you adjust your throttle position, it slides down to utilise the width of the base of the trapezoid to maximise valve duration.
hence it was valve timing with intelligence.
Erm... you referring to A-VTEC? :p
VTi just kicked in y0~
ahh
if its a 98 coupe
that would be a vtir
pretty daym sure coupes in that time dont come in vti
unless ur vtec fell off.....
Nope, VTi Coupe was available Pre 99 ;)
Post 99 was when VTi-R Coupe aka EM1 was brought in and the only other Coupe at that time was the GLi
facelift ftw~!
ah yes 96-98....my mistake
however i was serious about ur vtec falling off
LOL!!!
Its all good man hahahaha
VTEC Solenoid not plugged in properly, like someone I know lol ;)
Like you yoey. silly toyota driver hahah
