go to a proper mechanic and get a "leak down test"
this will tell you where there is leaks in your engine and intake/exhaust .
Then get a "compression test" to tell you the condition of your piston rings and upper head.
Then work from there
blue smoke is oil burning, not white smoke......
vetec motors overfuel when switchover happens perhaps this would account for smoke??
i know my lude blows a bit at that point
Put a Catch tank in, to see if you are getting blow by.
sounds like worn valve guide or steam seals. Leak down test will show this.
your the best vtecmachine!
im pretty sure its the headgasket :)
Have a mechanic do the leak test, check all your pistons are at right compression. Do you run ECU or AFC? Also your spark plugs are alright. Another is there is a possibility that the valve stain seal could be damaged. It's the seal that blocks out the air/oil when the pistons are working. You could alternatively try using thicker based engine oil, and see if the white smoke still comes. Most likely, is the pistons are leaking oil. check the compression.
