Sweet
Now we have that sorted...
What's the best type/brand for this job?
Thanks Guys
Luke
any brand is fine. Its just a can to let oil vapours go into
one vote for lipton ice tea bottle. it cheap and does work. lol
You really dont like to read. You dont like to comprehend. Or understand whats going on, do you? Just like to be spoon fed.
http://www.ozhonda.com/forum/showpos...7&postcount=45
Point 1.
So your telling me I can't just add a catch can?
Seems quite simple too me!
Turbo inlet - catch can - rocker cover...
I don't have that type of time you seem to have...
If I ever find the time to go into forums of a make of car I don't even own anymore just too pick and prod others I'll let you know.......
ive got an idea Luke. How about you just try it and see if, under any circumstances , putting some sort or catch can on this inlet pipe actually "Catches" anything.No real harm in it.
in this case , no it cant hurt.
On a NA car it wont do anything , but in this "boosted" instance lets see.
Just follow the diagram i put up guys. it tells you where to put the catch can
Guys
The PCV valve is one way on my EG5.... and mines in good working order :)
Ive read Limbo line and now understand the basics
http://www.beesandgoats.com/boostfaq/g2icturbo.html#PCV
A small amount oil in the turbo intake is better than just installing breather so I'm put mine back to stock till I get a catch can.
Limbo who moded your Intake so this setup would work correctly?
http://www.beesandgoats.com/boostfaq/PCV_turbo_2fit.jpg
i drilled 2 holes in the arm about 10cm apart (i didn't exactly measure, its a guestamate) then i put 2 rubber gromets in it. The right angle parts i used 2 small pieces of stainless steel pipe bent them carefully in a vice and intake done.
If anyone else wants to do them i'm sure you can use either brass or copper right angles from a pumbing supply, in case you don't have the stainless steel piping. Brass would prob be better out of the 2 as it doesn't corrode. Copper sometimes goes green if there is water & air present, but i think it this sealed application should be fine.
huh? the stock PVC valve is still in place, this setup is only to reduce the pressure buildup to allow the PVC system to work like stock without the added pressure in the manifold
Hey Guys
I picked up my Moroso Dry Sump Breather Tanks No. 85470 of Adrian at TODA yesterday..
http://www.moroso.com/catalog/images/85473_part.jpg
http://www.moroso.com/catalog/catego...?catcode=13400
I’m using this method.
http://i31.photobucket.com/albums/c3...t/diagram2.jpg
Block off the IM
Block off the Pre-turbo intake
Drill out the PCV valve so it flows both ways and also increases air flow.
Run one line from the PCV valve/black box to the oil catch can.
Run the other from the rocker cover to the oil catch can
I have a few questions…
1.What bolts or screws should I use to install the Catch Can bracket to the firewall?
2. Where can I get 3 x Male 3/8” to 1” hose nipple?
Example http://www.rocketindustries.com.au/i...mb_PR66369.jpg
