Spot on. Lol hence why mine is off
Is anyone rockin low seat rails?
looking at vanners tuner special at around $250aud delivered. only know of rps.13 who has it
Why don't you guys check whether the bolts are loose?
Anyone know if a dying alternator could cause struggle start? My car sounds like it struggles a bit to start, it doesn't start instantly like it use to. It's not so bad in my car but I'm just really picky with little issues and my other EP3 seems to have the same issue as well.
Could be the battery wearing out, when i changed my battery to a higher CCA rating, it started almost instantly
So, my engine light came on yesterday. Car still runs without skipping a beat so I have no idea what it could be. I disconnected the battery for about a minute yesterday and that cleared the engine light. But, it came back on this morning - car still runs perfectly.
Can anyone suggest anything? How can I diagnose the error?
Whatever you do, do not disconnect the battery again. This makes diagnosing problems that much harder for a mechanic. Best bet would be to get an OBDII scanner connected to the car and find out what the problem is
It is safe to drive the car, provided you drive it carefully. Most mechanics have OBDII readers. What state are you located in so I can direct you to a workshop?
Darwin, NT. :(
Don't know anyone up there unfortunately. Best bet would be go and see Honda
A couple blokes from a Darwin car enthusiast group on Facebook has offered to help clear it :)
Just installed a Jackson racing supercharger and on my first start i could see the car was about to overheat on kpro (100' Celsius), i notice the coolant is not circulating at all and the fans aren't cooling... what could be the problem? I've checked all plugs and they're all in the correct place and properly in. Waterpump isn't making any funny noises either...
I can't even burp it since nothing is circulating... I have a feeling it's the thermostat thats stuck closed, so i tried to unbolt the 3 bolts that hold the housing; only to find i've crossthreaded it some how... all three of them.. i dont even know how
It's the tegiwa radiator, everything is positioned pretty much the same as stock. The problem is that none of the old coolant is flowing thru the lower radiator hose or into the upper radiator hose to the engine block, its like the thermostat is not opening. last thing i wanna do is replace the water pump
edit: my ect is going over 100 degrees, thermostat should have opened at around 89 degrees. I also notice the engine bay gets really hot
i know what youre talking abt, happens to me all the time
its easier to do it few times so coolant heats up as a whole.
if bottom part of your radiator or lower hose is cool, tstat most likely will not open even though temp of coolant in head is 100c
FEEL the lower part of radiator or lower rad hose. if cold, tstat not opening.
I had a look at the pump and the pulley seems fine, no leaks or worn bearings. Tested the tstat in boiling water and it opens up. What i think it might be is an airlock in the engine block. Theres no water/coolant behind the thermostat so it can't open up since there's nothing to heat it up. Possibly? Gonna get the car towed to mechanic to do a powerflush and see if it helps.
Why not just fill the block thru the top hose?
Got the cooling problem fixed. Now Just gotta sort out the CEL light. Getting code p1259 telling me the vtec solenoid is bugged and going into limp mode. Might just take it apart to get the screen cleaned, anyone know how roughly much oil will drip out?
Update: I'm using a krpo base map with the k20a2 running jsrc. Could that be causing my cel to come up? Found out the jdm k20a doesn't have a vtec oil pressure switch. I unchecked it from kpro but it still comes up as soon as I erase it
Anyone know how I would go with fitting
Front - 17X8 +40-45 with 225/40-45/17
Rears - 17X9 +40-45 with 245/40-45/17
Stock height, stock camber.
Front experience if your running 17x8 +42 in the rear will be very close to your trail arms (what you call them sorry).
Will FN2 recaros bolt straight onto the EP3 stock rails? Someone on here had them, can't remember who
no stans no chans
Spacers?
You're right. Spacers are cheating.
Alright my bad, bought*
Oh yes because this is suddenly all about me not appreciating my wheels? I never said that to begin with so where are you getting this whole Christmas argument from?
All I asked was If there was a way to fit the wheels on; instead of being a dickhead you could have simply said 'No these wheels won't fit perhaps you should try 17x blah blah'
But instead you acted like you were some sick ****.
No need for the offensive language mate.
Maybe you should have searched first or go through the "FD/FN2/EP3 Wheel Setup Guide" thread to see if the wheels will fit. Or even check the DC5 fitments cause they are similar. A lot of people are sick of answering questions about wheels because someone else has asked it before and the answer is always stick to +35.
Just by looking at Symphorced's DP, he has clearly played around with wheels on a EP3 before so he will have some knowledge about fitment. So why don't you get some manners and search before you ask silly questions.
Come on guys anymore argument I'm deleting posts.
wow.......... this escalated quickly
Merry Xmas All :D
Contemplating on getting a mugen grille, but one part of me says it looks good and the other part says it looks out of place..
even genuine mugen grill doesnt really sit flush
not perfectly though just my opinion but i think it only looks decent if its moulded onto the bumper itself. some guys in the uk have done
ill find pic later when im on pc
Hey guys i think I blew my cat out cause there is a rattle coming from the exhaust piping but I got no fault codes, also drop in power after 6k big time would A blown cat do this ?
i just got my Hasport mounts installed in yesterday
and i found out it only came with 3 mounths instead of 4
is there a way on just getting the 4th mount from somewhere else?
hey guys,
pulley belt is giving me grief. tried to search in this thread for the size but cant seem to find it... anyone know how long the belt is for a jdm ep3r?
Steve is correct. I bought hasport 62a rear mount.
hardrace not stiff enough imo. not race car feel
anyway bit clueless here. RPS.13 has BHR67Z rear sway on his ep3
according to whiteline site BHR67Z (dc5) and BHR91Z (ep3) looks to be very similar, if not the same. however one is $299 and one is $265. dc5 and ep3 shares the same rsb afaik. wat the fuk, am i missing something here?
http://www.whiteline.com.au/product_..._number=BHR67Z
http://www.whiteline.com.au/product_..._number=BHR91Z
I'm sure we can use dc5r rear sways on our cars. I've a got a tanabe RSX on my ep3 at the moment.
can anyone check their crankshaft pulley at warm idle to see how it spins? Is it spinning smoothly and straight or does it have a slight wobble to it? recently changed to a bigger second hand k24 pulley to up the boost for my JRSC but it seems to be slightly wobbling; but straightens out above 1k rpm :S thinking i might have got a lemon pulley and its out of balance
My crank pulley on DC5 is spinning smoothly. No wobble.
Definitely shouldnt wobble
yikessss, can't be good for the motor.
welp... time to buy a new pulley to see if it fixes the problem then. hopefully its just the pulley and not something bent in the engine or something D: cheers
What are your thoughts about buying 2nd hand BC BR's roughly 1 year old? Or should I just continue saving up for new ones?
buy new.
That was my initial thought but I've started steering towards the idea of buying the 2nd hand coils for track day coming up. It'll be the first time I'm tracking so If I really like the whole idea of tracking I'll eventually save up for better coils in the future.
Just really wanted to know if coils wear out quickly or should a set of one year old BCBRs last me a while until I get more coin?
You're better off buying new coils if you want the best out of it, not just for tracking but also for daily. I wouldn't buy a second hand part that's subjected to all kinds of abuse (both user, mechanical and environmental) and wear and tear. Especially on such a vital part of the car. But that's just my opinion
There is an upside to buying used coils though, you can be sure that they aren't gonna break when you put them in.
Sure they might wear out sooner, but that's why you just take them apart and rebuild them
If they're rebuildable and if there is someone in the country to do a proper job of rebuilding them. Beware of suspension joints that claim they can rebuild any coilover, ensure they use the parts direct from manufacturer and to manufacturer specs, otherwise you'd be blowing a good deal of $$$ for a crap refresh that will last you less than 6mths...
