thought I would post up some pics of my $700 beauty-
ahhhh, its time to rebuild my gearbox,
anyone know where i can get syncros from?
and a good place in sydney that does gearboxes?
no worries, PM me what you want and if I decide one way or another I'll get back to you.
ok cheers will give it a go asap
I am sure I had a writeup somewhere....maybe its a some 100 page back when i did my projector fitment i wrote something about it. I used a hair dry and have to be patient when u take lenses out.
using hair dryer or heat gun will make sure you won't melt anything else unnecessary. but that means you can only lift up a section of the lense at a time.
I need some help atm
I need a VIN number for DA9 Integra LS
I did a Brake swap on ED9 Aus spec crx 242mm front brakes to 262mm front brakes DA9 Integra LS
i bought a set of ARP Long wheel studs and need to press out and brake the wheel bearing to fit the new long wheel studs on my hub
If anyone would be nicer enough can you PM me your VIN number for your DA9 Integra LS
Thanks pat
i know i dont have enough rep to post for sale but im wrecking a complete running da3 sx16 if anyone is interested please pm me im trying to sell some parts.
I am not sure exactly what you are after, but if you need a front wheel bearing just go to CBC Bearings and ask them. The part number is HO125A suits DA9 Integra, and should be about $65 each.
I have a spare but if I read correctly you need 2, plus i would be unwilling at this stage to part with it in case I decide to fix up the red car.
BTW- I believe Honda ask about $160 a pop.
