http://img.tapatalk.com/d/14/08/12/bygyje3e.jpg
Dis my car wen lite up at nyt
No h8 plz
<3
No h8 plz
<3
I am from Perth WA. Sorry for the no intro and popping out of nowhere but have been avid fans of Ozhonda members rides. I just brought my fd1 about 3 weeks ago. First mod in was the mugen showa coilovers and then the 17x8 enkei.
Perhaps i should rephrase" smallest wheel diameter" to best tyres size for handling and looks based on 17x8 rims. I really adore the setup that you and chrischris have but i don't think i can pull it off knowing lowering springs will take 1-2inch off. Hence trying to go lower by changing tyres size without touching the springs or affect the ride too much. I do agree with you that my springs could possibly be swapped.
I was inspired by the first FD Type R concept by SPOON based on a FD1 chasis many years ago. They had a F20 head on a K20a block inside.
http://cdn0.vox-cdn.com/uploads/chor...621435_730.jpg
Natsrs, coming together nicely man, not far to go now ;-)
Hi fellow FDs owner,
Got a few question in relation to swapping seats on fd vtil and sport.
1) Which manufacturing year fd vti does not have side airbags or OPDS?
2) Is the SRS module unit connect to the ECU of the car?
3) Will i have any issue if i swap my current vtil SRS module unit with a non side airbags SRS module unit say from 2006 VTI civic? Non-crashed SRS unit of course.
4) Also anyone know or tried to swap Integra Type S seats with airbags and OPDS into a FD VTIL or Sport? Any issue with the SRS unit registering the new seats?
Thanks and look forward to inputs from experienced FD gurus
If you are going for a functional build then I would go for something around 215/45, 225/45 or 225/40.
In order for your car to handle better you need as much contact to the road as possible. So chunky tyres is a must.
But even 215/45 on an 8" Wide rim isnt even chunky.
Its hard to get best of both worlds. Its either built to Function or Hard Parked.
@JPrak
M8, Join the club and get HIDs!
Agreed, it's hard to get best of both world. I will try 215/45 and maybe move to 225/45 later stages. Thank you for your advices there are valuable to me
All good.
As of your Seats question. A member did a FN2R seat change in his FD. Not sure if he had Airbags in his original seats
but he had to pay about $500 to get the FN2R seats in his car. Think JPrak had to do the same but with his Recaro seats.
I swapped my driver seat to a Recaro seat and currently driving with my SRS light on. Doesnt bother me as much
but will be getting a resistor sooner or later to get rid of the light. Right now its throwing the code out and bags wont deploy if I get into an accident.
But then again. Safety is for faggots anyways cause #YOLO.
Jokesss Lol. Just havent had time to get the resistor yet.
http://i194.photobucket.com/albums/z...47101113_n.jpg
Sometimes we all like to live on the edge LOL
Anyway, correct me if i am wrong but the resistor is just to bypass the side airbags for both driver and passenger seat but to bypass the OPDS on the passenger seat is whole different story.
From what i know the below method to bypass the OPDS;
1) Take the OPDS and sensors from original seat and stuck it to the aftermarket seat. ( Read a Accord Euro CL doing this)
2) Buy a pair of FD2R seats and basically plug everything in ( rail mods required i believe) ( i have also read USDM Honda Fit with SI seats-apparently their current SRS modules accepts the new seats)
I am investigating the below unproven possibilities:
1) Swapping out the SRS module to a non side airbag SRS module ( say 2006 VTI civic)
2) Swap Integra Type S seats w/ side airbags OPDS
Please to hear any comments from fellow members
So I did something similar to this about 2 weeks ago to my car, I'll try answer your questions for you.
Pre-facelift 2006 to 2008, has no side airbags in their vti models, correct me if I'm wrong
There's apparently a control unit in each seat which communicates to the computer of the car, (abit vague, i'm not sure if its srs/ecu modules)
If you car comes with airbags, and you swap it to seats with no airbags, you will have the airbag light appearing. rendering ALL airbags off. I think your question refers to SRS itself to make it not even look for a side airbag right? Then not to sure, in theory it seems plausible.
I swap, 2011 leather FD2 front seats, with my airbagged 2011 FD1 seats, and even though both contained airbags, and from same chassis, i still had the airbag light error. I took it to a work shop, resetting the code to clear it wasn't enough, the error just pops up again after you start your car again. Using the "paper clip" method, had the same result, the error appears.
I took it to Honda, paid about 130, they had to reinitialise the unit (i guess format it), and then reset it (match it with the cars unit). And it worked fine. NOTE: if you do go this option, make sure to get the VIN number of the car you're getting the seats from, it assists Honda with the process.
Ain't a guru, but You're welcome :D
I was on mightcarmods forum, and milkchicken (honda fanatic) told me of the same process, remove the control unit in each seat, and shove it in the aftermarkets, to make the computer think it's still connected to the factory ones. Was going to do it, but didn't like the idea of chopping up my stock seats (head onto 8thcivic, there's a DIY .pdf file that shows you step by step in taking apart your seat), and the fact it would be time consuming.
JDM FD2R seats do not have airbags, from memory
In theory, yes.
I wanted to swap FN2R seats, which have airbags, and pretty sure I have to take it to honda to do the same process. I'm not sure seats from a different model car would communicate the same.. as mine was from a FD2 to FD1, so I assume it was be kinda of more simple.
The member was DUFFY_FD, he didn't have side airbags in his original seats.
Jprak, also didn't have side airbags in his stock seats either.
Thus, neither had the airbag light error.
Hope my answers are helpful, I spent weeks of research, but couldn't get a definite answer, but I really wanted the leather, so I just yolo. Hope the above helps fellow/future FD owners.
Duffy_FD and me had to do custom rails as it wasnt a both straight bolt on
he had the FN2R seats while i had the evo ones.
BAO BRAH! HIDs on our FDs are bright as ****...i hate it LOL!
Not even brooo. I point mine down and doesnt blind anyone. Get 6000k HIDs!
I got them pointed down before I started modifying my car and because my car is
lowered now I can barely see ahead of me lol. Can probably see 5m ahead of me? Or even less.
Need to readjust them but no time
Im thinking about retrofitting projector lights in.
Anyone recommend a good brand for projector lens?
Or should I just buy S2000 lens? Heard They're one of the best?
I didn't adjust my headlights when i first put HIDs in, and already it was pointing slightly closer than halogens. My HIDs in my foglights were more blinding than the HIDs in the low beams..
Retrofitting is good, just go TheRetrofitSource, they are quite pricey and the Quality control isn't the best, but they've ironed out a lot of the issues by now. It's a good read, talks about all the diff types of lenses/projectors, and yes the s2000 are great.
SharkChu thanks for the input and congrats on the seat swap. I have also been researching for quite sometime on this matter.
I need to apologise as I stated wrongly on the fn2r seats..they do come with airbags n opds. I think with your recent experiences its proven that the srs module cannot interact directly with either a different airbag or opds from another car without resetting.
The only option yet to be tested is swapping a non airbag srs module unit. Hence I am curious if the module itself is connected to the car ecu. From my research the module itself its not cheap as wreckers have many that are not usable due to airbags deployed during accident. It would be great if someone with this valuable knowledge can shed some light.
Unfortunately im in Perth WA. I am actually looking for a used fd sport steering without airbag. I have a thing for leather as well LOL lemme know if anyone can source one for me..cant find much fd wrecking here
Any of you guys got aftermarket pedals?
My hate was only to motivate (or something like that. Everyone's seen the DGK stickers)
BUT!! When it's finished (or at least painted) I will be eating my words. Or I can post a video of me punching myself in the dick really hard)
You'll probably have the best FD in AUS
I got mugen pedals
Get them pedals dirty and wear my shoes uneven
Lelz
What you guys think Evo gsr or mr recaros (9)
Thinking changing my Evo 7 ones
Threesix trust me I'm waiting for the day I get my car painted completely I hate it looking that. I'll be honest but it shits me seeing it like this.
Just few parts from japan and stuff from aus and should be good to go man. I'm putting too much $$ into detail esp in the interior, think I went over board on interior from Jpn LOL.
Is there any difference between Blue and Gold HardRace Rear Camber arms?
Or are they both the same but just different colours?
Both will fit our FDs right?
Blue -
http://www.ebay.com.au/itm/HARDRACE-...c778197&_uhb=1
Gold -
http://www.ebay.com.au/itm/HARDRACE-...a33bef7&_uhb=1
both same?? i see no difference...
i got the old ver. of the camber arms <.<
http://www.velocityshop.com/images/p...e-cvc-fd-1.jpg
@DAN Lol ***** please!
You guys know whats the lowest bolt on spacers we can run?
Looking into 15mm bolt on spacers but heard some cars need to trim their stock studs to put wheels on.
Would 15mm clear our studs?
Might buy this
BWR made rear subframe for 06+ civic
http://img.tapatalk.com/d/14/08/17/usuhyqa7.jpg
Did you get your spanners back Hondafd?
are you track your car jprak?
Carbon J's Lip arrived this morning. Slight modifications to get it to fit.
https://scontent-b-lax.xx.fbcdn.net/...85619041_n.jpg
Lol looks like our cars the same XD
Getting few bits and pieces from japan
http://img.tapatalk.com/d/14/08/19/ba7yvaze.jpg
Just bought FD2R steering wheel
Yeah Fd2R door trims
Currently experimenting my spare door trims
http://img.tapatalk.com/d/14/08/19/a5eru2y9.jpg
depending on your wheels you dont need to cut the studs. if your wheels have the small gap next to where the stud goes through http://mbworld.org/forums/attachment...-rims-back.jpg
http://i745.photobucket.com/albums/x...psigimpiwl.jpg
Love love love
Where can I get some cheap side skirts (melb)? Mars performance has some mugen ones for 300$
Ontherunmotorsport sells them
OTR is about the same.
Thinking of injecting my mounts or at least the dog bone, what ya reckon boyzzzzzz?
Too much effort etc
It will reduce any movement from the engine, but in return it will increase vibrations transfered to the chassis at selected RPMs, as well as overall cruising noise.
It won't improve your performance and it certainly won't improve your comfort while driving. You'll almost certainly want to buy an extra mount to do it as you should let it cure for a period of time before using the mount again.
Overall, its more effort than its worth and its only worth it if you're planning on tracking your car.
Thinking of doing just the dog bone which is an easy job to increase dem shifter feeeelz and reduce the bunny hopping
Yeah the bunny hopping is pretty annoying at times, if you are committed definitely get an extra mount to try it out, so if you don't like it you can switch back. You do get people say that once its worn in, its not as bad, but I think its more the fact people get used to the extra noise and vibrations.
For me when I tried it with a different mount, the extra vibrations and the fact the whole dash would rattle made me switch back to stock.
Yh nh if dash rattles will def go back to stock
https://www.facebook.com/groups/7922...0078059340462/
genuine mugen rr bumper..
Hey guys! Back in Melbourne after 3 weeks of holidays and body clock readjustments :P
What's going on? :)
I saw Honda_FD attend the TPNM 3rd Birthday!
Guies I spotted a real type r!
http://s27.postimg.org/wqacotq5v/IMG...826_133528.jpg
Dats me
That repainted rear end for extra multitone
Kindly asking if you have any suggestions to bypass the OPDS module + sensors on the passenger's side beside removing them and installing em on the recaros? This is all based on fds with side airbags + OPDS.
New plates ordered. Will match nicely with my bronze TE37SLs
https://fbcdn-sphotos-h-a.akamaihd.n...17285635_o.jpg
They do come with bronze.
http://i.imgur.com/Oz6Pkuf.jpg
But if order brand new there are only 2 colours. Grey and Black
If my 3 piece Work Meister is leaking air out of a few bolts does that mean I need to take it apart and reseal the lip and barrel? Both rear rims has an airleak
