lolz, no idea what mine is on, havnt had a wheel alignment :P
do u guys think 18x10+30 going to fit the rear or cl9? (rolled guards) i am guessing not, but i think i should ask just to confirm, coz i am thinking of getting 18x9+30 front and 18x10+30 rear re30 style black on my black euro
the 18x18+30 will fit, the only issue you may have is the offset not being low enough as the inside of the wheel might rug the strut. You may need to run a spacer, anywhere between 5-15mm. Just of the top of my head, im pretty sure you will need a 15mm spacer to make it fit.
18x10 +30 should work fine if you run a 10mm to clear inside strut. just test fit and go from there :) either it will rub a little or not at all, and if it does rub just add a spacer and more camber to fit.
a roll/tab mods/and a flare if you don't want to poke too much will help too.
I thought they were +22. +12 pwah... lol. Love your car
wow +12 !!!!!!!!
SO hot felixd
what rims you got now felix. and could someone please explain to me what +22 or +12 is i know its about the rims size but the more the deeper or? :S
Really do want to learn wheels lol.
im not sure whats next for me as i need to sell the car first :) then from there ill see what i can get.
SuperJDM: its the offset the less the number the bigger the dish :) and the more out ur wheels sticking out from the guard
