i used the 1/2in and 1/4in sanding drums with the 60 & 120 grit rolls.
http://mdm.boschwebservices.com/MDMC...0/r00164v1.jpg
then 400 and 800 wet/dry to smooth it out by hand...
I just got myself a b20 block and an engine stand.
My engine stand mounting points are 70mm long.
The Engine block has 4 threaded (10 x 1.25) holes I presume
And 3 through holes.
Which holes should I be using to mount the engine?
It doesn't matter, just use common sense and hold the engine securely.
The through hole can be used no dramas.
Check yellow pages for a fastener shop in your area
Supercheap and repco are useless. I can't beleive they are associated with that name considering what they sell, especially supercheap.
If you're in Sydney, southern area, hit up Industrial Fasteners.
