im sure this is covered elewhere on the forum so i wont waste everyones time with questions. but can sum one point me in the direction of info on obd0 and 1, like on the differences etc...
from wat i was told from someone, obd0 is like comparing intel pentium 1 with a dualcore, obd1 processes fast and just better to use
but i cant say from expierience
So far i have Skunk2 I/M & T/B and Weapon R intake, will be getting cams, and eventually once i get all parts together , turbo it.
Now ive been told you cant boost on obd0, and ive also been told that to get the best out of my Intake setup and future cam setup, converting to Obd1 would help in the tuning department, and to achieve both of these and provide me with a faster ecu at the same time, so i though why not start by converting to obd1 so that once i get my car back on the road i can go get that initial tune so she is a happy DA.
I've had my OBD0 Xsi for the best part of 10 years and have done a fair amount of work to it except an OBD1 conversion. I've also boosted the b16a with an obd0 ecu, you just need a rom editor that will support extended maps into the +ve range. With the OBD0 ECU you can connect it to a laptop via usb, tune in real time, upload maps, datalog, launch control, anything really. The problem is, most have no experience tuning OBD0 ECU's here in Australia so if you want someone else to tune it, convert to OBD1, run what the tuner recommends and call it a day. Otherwise, just tune it yourself, and no it won't blow up if you research properly.
Mate you made that sound so good, just yeah I would need a laptop first lol, getting someone else to just do it (tune) would be preffered, trying to do as much as possible but don't wanna overload myself with stuff, befor I started on ozhonda, I would just take my cars to a machanic,
trying to research how to rebuild a b18a and how to turbo afta, wanna look this up heaps as I don't wanna buy all the parts and then get half way through and relise i've done something wrong, or worse think it's good , then drive it and blow engine or something like that. So if a obd1 conversion isn't hard, and it will be tunable by a good tuner, I think I'll try it, would most wreckers have the obd1 ecu and dissy? is there a specific ecu I need to get? Obviously a manual obd1 ecu, p -somthing??? And what car does it come from? So I can check wreckers
odb1 was used int he 92-93 da9s
Well I won't find one of them at my local wreckers lol,
will check other Honda wreckers,
cheers stevo
i used ry-wire to convert from obd0 - obd1
Hey man ,
had a look at Ry-wire.com
http://www.rywire.com/catalog/obd0-m...kage-p-69.html
is this the one you got?
and is it a good price?
and did you buy it online?
cheers
thats a very good price!!
but i went a step further
http://www.rywire.com/catalog/milspe...rness-p-1.html
thats the one i got,
you order it from them and they make it to your specs,
i wanted aircon, but no power steering so they did that.
well worth the cash i think
hey guys Skunk2 Intake Manifold for B18a how serious a job to fit to da9 91 model? is it pretty much a straight swap or have i gotta move/modify some things...
