i dont have the factory ballast and it only come with the h4 philips normal h4 55w globe. yes its straight forward to plug the hardness but the low beam from my aftermarket just not working but the high beam works,. thats all the story..
Phil...they cut the original loom and modify it to fit std H4's.
ITRDC2...OK, are you talking about the rubber boot which sits behind the globe?? To fit the HID, cut a slit at the bottom of the boot downwards about 1 inch. Then you should be able to squeeze it past the HID globe.
Most HID kits have a direct fit H4 male plug, so you just stick it into the existing female plug from the car.
yup that helps i know what u mean the method of cutting the rubber boot now, yeah i know plug to plug, but it just not working. i will meet the hid guy tonight i will get him to test out, hopefully i didnt burn the low beams, so that in case i can change over from him, thanks for your advice
u guys rekon i would see a gain by changing to BC headers without changing the cat back?
^ i think the key there is kpro...
i heard a lot good feedback of kpro, but how about spoon?
