Im running toyo T1'S at the moment, they are awesome rubber.
The reason i need shocks now is cause my old ones are ****ed and if i dont change them soon bad things may happen lol.
Ah. lol.
Best to go with the Spring Shock combo first then. As i said if you could afford it I would probebly recommend Spoon Straights w/ Koni Yellow. If not Koni's then KYB AGX. Unless your worried about comfort and in that case get progressives ;).
The only form of "preloading" you can do with the Ground Control kit is in order to keep the spring captive much like a stock spring. Once the weight of the car comes down, the final length of the spring will be the same regardless of where you place the spring perch.
Hit spoony with some REP POINTS, i did, he deserves it.
Who sells Koni yellows on here, anyone?
This dude does here
http://www.ozhonda.com/forum/showthread.php?t=55668
Thanks bro, **** i need under a grand :(
1000 is my limit, hit me with some ideas?
Swaybar yes but unless your installing a camber kit for a detailed wheel alignment...(presuming your just installing it to remove negative camber) it would negatively effect handling and cornering grip but improve straight line grip.
Honestly, you would be better off waiting, saving and getting the best your money and your financial situation will allow. If you just purchase springs you will regret it later. I would look on American Ebay and see if anything pops up. If your willing to save for a while I would recommend the Buddy Club N+ if not a Ground Control/Spoon Spring combo with KYB AGX or Koni's (again if your finances allow).
KYB AGX + Spoon Springs (Exact drop you wanted) New <$1200
Koni + Spoon Prog. Springs (Unsure of Drop) New >$1400++
Unsure of Spoon Straight/Ground Control prices considering the AU$ is r00ted at the minute you would be best to probebly buy locally.
I was thinking of selling my combo in order to purchase a set of FIGHTEX coilovers...but I decided to buy wheels instead...however if your willing to wait we may be able to arrange something. Pretty sure modification would be required to fit DC2 suspension into an EK...would have to ask around.
u think just bc u drop the car u have camber for cornering?
camber kit is available bc honda have crap camber tops that dont have camber adjustment.
getting a good alignment on shocks and springs would be as good if not better then coils.
EDIT: who would pay for a camber kit to remove negative camber on a honda?
