Go full clockwise first. You don't need to use force. A light finger is all you need. Once you hit the end, stop. Then count while turning anti-clockwise.
found out for myself the other day, its 15 turns front and 13 rear. I just kept turning until it gets really hard then i'm at the beginning or end.
I've set mine to 7 clicks front and 9 clicks rear and seems comfortable to drive around on.
Does anyone know how or if its difficult to adjust the height of the buddyclub N+ coilovers so i can do it myself? Pedders charged me something like $70 to adjust the height last time and $110 for a wheel alignment front and rear. Also i'm guessing the camber kit i have installed will need adjusting when raising or lowering the car as well.
I know i'll need another wheel alignment when lowering it again but i can do that cheaper somewhere else
wow !!! its not hard. Ull basically need a tape meter and pen and paper. adjust the desire height u want and record it :D
you need to measure about 2 sections.
the top mount to spring seat and spring seat to thread level. <-- make them equal on both sides and your done.
as felixd said it's pretty easy, loosen the thread seat @ bottom and twist thread shorter (clockwise).
height you do yourself and take it to peddars or heasman for alignment for $110.
If your turning clockwise and you get to the point that is hard --> HARDEST setting
If your turning anticlockwise and you get to the point that is hard --> SOFTEST setting
So from what you said i am assuming you were running 0-2 damper setting which is pretty soft.
But riding in .QD's N+ on 10-7 it was still damn comfortable.
you lower the car and they do the rest.
