Awesome! :D
And if building a k20/24 is there a better bottom end to start with? Are aftermarket pistons and rods required, or will decent power be made with stock bottom end and k20 itr head
Pretty much becasue people just follow what's on the net.
& If your start point is a CRV bottom end, then yeah, good idea.
You can't really convert that one as there's no provision for the lost motion assemblies (springs)
But if you've got a K24A from a Euro, the head is good.
The money spent on a head swap could be better spent on other things...
(Only down side is you'll need K20A spring seats & retainers to use K20A aftermarket cams & springs)
But hey, don't let me stop you,
& can I have your old K24A head when you're done?
http://wiki.clubcivicquebec.com/imag...ypes_V_tsx.jpg
If your on a budget, start with a Euro Accord K24 motor. Change valve springs, 50VTC, stage 2 cams, ITB's and decent headers, you'll see it make 150 + kw (depending on dyno)
Check out some of my youtube video's when i had only a internally stock k24 motor with itb's, asp headers and E85 rev cut @ 7400rpm
how much does a k24 setup go for these days?? basic i/h/e kpro and all the parts required.
depends on heaps of things: new or 2nd hand parts, if you pay someone or DIY, etc etc.
drive in/drive out around the $10 - $13k mark from what i've seen
wow that is alot cheaper than i thought,, yes brand new parts
Hey guys, just about to do a k24/20 conversion. I bought a 07 k24a3 and now i just need to know if i need any other parts to make this work. I own a ep3
k24 CRV engine side bracket. If your swapping over heads, might want to get a new Headgasket. Other then that its pretty straight forward, have the honda manual handy.
I was on real budget with my EG civic K24A swap
Stock k24a3 motor with 50 degree VTC , Stock k24a3 valve springs and cams , 7600 rpm rev limit , Hondata kpro , Custom Intake manifold with 80mm throttle body , Custom header , 3 inch exhaust on 24.5 x 8 x 13 slicks got me 11.82 @ 113 mph down the 1/4 mile.
