Originally Posted by
TbM
Dorikin my TPS was at 0.51 volts at closed throttle and i adjusted it and noticed a difference so would recommend doing it, i had to hacksaw a line in mine and remove it with a flat head but it doesnt take long. I dont think the wot reading is as important as the closed.
If you didnt clean the IACV properly the first time then that could still be causing your idle issues, use subaru upper engine cleaner or if you cant get that bezza knows another cleaner that works well and remember to let it dry before reinstalling it, reset the ecu when your done. Ive never needed to use wd-40 or other lubrcants when i fully clean the IACV, if its sticking its still dirty.
