i use rattle gun on every single car i work on no problems i see these car every 4 months for the last 4 years
buy a cheep can of bbq butane gas like desposible cans for a portable stove top bash a socket on and spray the gas on the nut FREEZE AND RELEASE works quicker with less damadge on siezed parts while your mid DIY in ya backyard on a sunday
probably crossthreaded az F***K
^^ can someone please explain about this freeze n release technique
explain it to me a noob as i have no idea about how to do this
thanks
try jacking the car up first
it might help.
1/2" rattle gun aint the same like 1" gun
find the biggest pole in your area, chop it down and use it as a breaker bar, invite all your mates and have them sit/jump on the bar.
I'm not sure if your serious.
This may seem like a stupid idea but if you try and tighten it and then loosen i have found sometimes that works.
If that fails i would wd40 and breaker bar hope for the best.
Then grab the breaker bar and hit the guy who tightened them up natsrs
I would say horrible move.
Mostly because the wheel is not on the ground, so it'll spin freely... unless it's in gear, which I imagine isn't very good for the gearbox... I don't know if it's bad for it, I just like to think it's bad for it. Handbrake, eh. (towards the quote you quoted I mean... just realised that as I went to post this... derp)
So yeah, as I said earlier, get a 1/2" breaker bar, get the socket size you need, put it on there, get a huge goddamn piece of pole, wd40 if you must, and pull or push on the bloody pipe. It SHOULD undo it. If not, things have gone sideways, and I'm stumped.
