:thumbsup:
I believe it is your map sensor too. If you don't know what to do, just take it to the dealer and ask them to do it and clean out the connection.
you should check the oil after starting the engine.
then if its just under the full mark ist ok
you will find it might be lower after a start up, but still shouldnt be the problem
have you been able to check the ecu for fault codes
have you ever noticed the engine check light come on while driving.
also just coz your engine oil is right, that does not mean the oil pressure is ok. it needs to be tested with a pressure guage.
90% of VTECH problems are oil pressure related.
had the ecu checked and oil checked...im gonna change the sparks today...the vtec engages as nomal its just the power delivery that is inconsistent. it doesnt rev up smoothly when im going full throttle
Other people have had that problem on S2ki btw, search for a Map sensor Fix or Vtec stutter and you'll get your answer
thanks guys problem solved....was the map sensor.:thumbsup:
