thats what i just said up there.
but anyway this mods should be good for you:thumbsup:
VAFCii and the Neo are insufficient as they cannot control VTC and ignition timing. You will either have to get a custom reflash or go k-pro using a harness and a k20a ecu. There should be other brands of ECUs available for the Euro and those will work as well. Before choosing an ECU, I'd choose a tuner first.
Hmm.I hope you've got deep pockets EUROO3act.
Use the Hytech k24a/k20a ecu harness. You run 2 ECUs. The k20a with k-pro runs the engine and the k24a runs your A/C, cruise control and it might even keep VSA working (just guessing though). Downside is that the harness costs a few hundred USD, and a k-pro'd k20a ECU isn't exactly cheap.
