:) quick reply indeed, still up apparently :) Thanks for your advice, yes, what's done is done and I should just think this way: even wasn't run in the best but with today's high manufacturing standards, it won't be a disaster anyway!
I find that the hook that holds the bonnet down when closed is not tight enough and allows the bonnet to move up and down a few mms causing a rattling sound at low rpms and take off. I have fixed this sound and a few other euro friends of mine by putting some electric tape around the hook to make it tight enough when closed. You can replicate this sound easily by pressing down on the front of ur bonnet and releasing again repeatedly, I'm pretty sure all Euros have this problem, and it would be the first thing I would fix before other rattles because it took me a while to realise that the noise was actually from outside.
Old thread but as some may know I have the vibration above 2000rpm too butcan't find the other thread, it's like buckled wheels but under load only.
Took it to Honda yesterday but they still have my car to fix the 2 recalls on the Euro. Talked to the tech and he recons its the CV joint, lets see if he is right, somehow I think it is Head related.
i would have either considered lugs or hub problem/ wheel bearing.
Or
Your choice of CV joint.
When is the last time you balanced and aligned your wheels?
Btw what sort of vibration is it jerky bumpy sort of vibrationg or constant droney? and what mods on your euro if any.
A CV joint would give a knocking sound. Not really a vibration. And my Euro had this 2000rpm vibration from new.
I seem to find it's more noticeable when going down a hill with my foot completely off the accelerator pedal at 2000RPM as opposed to going up a hill at 2000RPM. I don't know why the difference but.
