Originally Posted by
Peppy
Well, one of the best suggestions that I've heard is the bolt that holds your back seat down.
I've used one of the bolts that holds on my tail lights, and it's worked well enough.
Do you know how to disassemble your back end? (All plastic moulding, boot floor, spare tire and back seats)
*edit*
I just headed outside and had another look, and here are the other good spots I saw.
Where your spare tyre goes, there is a bracket that the long bolt you use to hold it in place goes.
There are pre-threaded holes that'll be solidly welded in place under the little plastic discs 300mm on each side of your boot latch. I believe these holes are intended for anchoring child seats to.
