New wheels, new tyres. Kumho KU31s 195/50/15 on black racing sparcos +35.
replaced the dizzy cap and coil because they both shat themselves last night ><
getting two new driveshafts installed tomorrow. yipee. also gonna scrub some crusty bird crap off my windows
anyone know where to get new gas struts for the rear window hatch? and that little plastic gromet thing that connects to the window?
Washed the EG, did a service, vaccum the interior and Did some wire tucking :)
http://photos-d.ak.fbcdn.net/hphotos..._4950654_n.jpg
got my recaros steam clean :)
some one offer me a civic to buy in QLD
0466 598 136
i believe you can wire tuck the headlight harness without putting the original harness under the knife, by running the harness through the fender and not through its existing firewall entry? i read an article about it somewhere. by all means if you know what you're doing you can go extend wires by cutting but some may end up running into electrical issues later down the track? there was also talk about keeping the distributor wires (blue and grey correct me if i'm wrong) intact and not extending them as problems arise?
not attacking anyone here, as i've been looking up info on wire tucks as well, hopefully doing it soon lol.
anyone wanna confirm/shed light?
i've actually tried using the same harness and hid it somewhere, but unfortunately, the harness was too short to reach the headlights/indicators and etc, i've done wire tucking before and it was a job well done. The way i wire tuck it, i had spare harness which had the same coloured wirings.. so i used that for the extension. In order after than, i carefully stripped it, soldered each one and use those heat rubber thing (where you slip it in where the connection is, heat it up and it kinda squeezes together - i forgot what its called)
Im not wire tucking those major wires like distributor or anything, just doing the ones that are safe to do if you know what i mean :)
back to topic ; i installed my EG6 cluster which i received last night
http://a5.sphotos.ak.fbcdn.net/hphot..._4576371_n.jpg
